Novice seeks help with networking/telnet problem
Archived from groups: comp.os.ms-windows.networking.windows,microsoft.public.windowsxp.work_remotely,alt.comp.networking.connectivity (More info?)
Hi there - please forgive my novice'ness....
I have a computer at home running XP Pro connecting to the internet via a
Draytek Router and I want to be able to access this PC using a mobile
PDA/pocket pc running WM2003 (Has GPRS internet connection).
Can someone please help or direct me to a guide on everything I need to do
as I have been playing around for days without much luck. I have terminal
services on the PDA and the router gives my PC its IP address etc. What do
I need to do at the PC and/or router to allow me to connect remotely from my
pocket pc?
Help much appreciated....
Chris
8 answers Last reply
More about novice seeks networking telnet problem
  1. Archived from groups: comp.os.ms-windows.networking.windows,microsoft.public.windowsxp.work_remotely,alt.comp.networking.connectivity (More info?)
    Look at this page for help with that. I use an iPAQ 5555 PocketPC to access/control an XP Pro box
    using TSC and Remote Desktop...
    http://theillustratednetwork.mvps.org/RemoteDesktop/RemoteDesktopSetupandTroubleshooting.html
    http://www.microsoft.com/windowsxp/using/networking/expert/bridgman_02june10.mspx
    Al Jarvi (MS-MVP Windows Networking)
    Please post *ALL* questions and replies to the news group for the mutual benefit of all of us...
    The MS-MVP Program - http://mvp.support.microsoft.com
    This posting is provided "AS IS" with no warranties, and confers no rights...
    "Chris-John Turner" <sacrum@clara.co.uk> wrote in message
    news:1102467337.60404.0@dyke.uk.clara.net...
    > pocket pc?
    > Chris
  2. Archived from groups: comp.os.ms-windows.networking.windows,microsoft.public.windowsxp.work_remotely,alt.comp.networking.connectivity (More info?)
    In <1102467337.60404.0@dyke.uk.clara.net>, "Chris-John Turner" <sacrum@clara.co.uk> writes:
    >pocket pc?
    Would not you need a permanent IP address for your home router and PC?
    Without it how would your mobile know who to call?
  3. Archived from groups: comp.os.ms-windows.networking.windows,microsoft.public.windowsxp.work_remotely,alt.comp.networking.connectivity (More info?)
    Hi there...have looked at this site but am having no joy.....
    I'm guessing in simple terms I must identify my public IP given by my ISP
    and port forward it to my home pc private IP (Static) and telnet using the
    public ISP - have have tried all this but telnet just times out!
    Do I need to do anything else with my router - it does have a link in for
    teleworkers....?
    I think I can't see the wood for the trees.
    "Sooner Al" <SoonerAl@somewhere.net.invalid> wrote in message
    news:uD$xMOR3EHA.3376@TK2MSFTNGP12.phx.gbl...
    rights...
    a
    do
    terminal
    do
    from my
    > > pocket pc?
    > > Chris
  4. Archived from groups: comp.os.ms-windows.networking.windows,microsoft.public.windowsxp.work_remotely,alt.comp.networking.connectivity (More info?)
    Yes, as noted on the page I pointed you to you need to forward TCP Port 3389 through the router to
    the private LAN IP of your desktop. What router?
    http://www.portforward.com/routers.htm
    There is also a section on the page I pointed you to that talks about how to determine the public IP
    of your router and how to address the issue of a dynamically assigned IP address from your ISP.
    Have you tested Remote Desktop access from another PC on your home LAN first to make sure that its
    setup and working locally? If not, that really is the first step...
    news:1102504904.27962.0@nnrp-t71-03.news.uk.clara.net...
    > teleworkers....?
    > rights...
    > a
    > do
    > terminal
    > do
    > from my
    >> > pocket pc?
    >> > Chris
  5. Archived from groups: comp.os.ms-windows.networking.windows,microsoft.public.windowsxp.work_remotely,alt.comp.networking.connectivity (More info?)
    My router is a draytek vigour 2600....
    So from my pda:
    telnet to the ip linking router to internet provided by isp
    and router
    port forward from public ip to private ip
    do I need anything done at the xp pro end?
    thanks for help
    news:u9FkwlR3EHA.1392@tk2msftngp13.phx.gbl...
    rights...
    ISP
    the
    for
    > > teleworkers....?
    mutual
    > > rights...
    via
    > > a
    to
    > > do
    > > terminal
    What
    > > do
    > > from my
    > >> > pocket pc?
    > >> > Chris
  6. Archived from groups: comp.os.ms-windows.networking.windows,microsoft.public.windowsxp.work_remotely,alt.comp.networking.connectivity (More info?)
    You need to enable Remote Desktop on the XP Pro box at home...
    news:1102507551.9080.0@lotis.uk.clara.net...
    > So from my pda:
    > and router
    > thanks for help
    > rights...
    > ISP
    > the
    > for
    >> > teleworkers....?
    > mutual
    >> > rights...
    > via
    >> > a
    > to
    >> > do
    >> > terminal
    > What
    >> > do
    >> > from my
    >> >> > pocket pc?
    >> >> > Chris
  7. Archived from groups: comp.os.ms-windows.networking.windows,microsoft.public.windowsxp.work_remotely,alt.comp.networking.connectivity (More info?)
    Thanks for help - not sure what I've done but can now telnet onto my home pc
    remotely - is there settings in xp or on wm2003 where you can set the level
    of graphic etc?
    Cheers
    news:%23XnVF%23R3EHA.4004@tk2msftngp13.phx.gbl...
    rights...
    > > So from my pda:
    > > and router
    > > thanks for help
    how
    IP
    mutual
    > > rights...
    > > ISP
    using
    > > the
    > > for
    > >> > teleworkers....?
    > > mutual
    > >> > rights...
    internet
    > > via
    > >> > a
    mobile
    need
    > > to
    > >> > do
    > >> > terminal
    > > What
    > >> > do
    remotely
    > >> > from my
    > >> >> > pocket pc?
    > >> >> > Chris
  8. Archived from groups: comp.os.ms-windows.networking.windows,microsoft.public.windowsxp.work_remotely,alt.comp.networking.connectivity (More info?)
    Blimey - it was working now all I get is server timed out -terminal service
    stopped.
    Is this normal?
    news:1102516383.42549.0@doris.uk.clara.net...
    pc
    level
    > of graphic etc?
    > Cheers
    > rights...
    > > > So from my pda:
    > > > and router
    > > > thanks for help
    Port
    > how
    > IP
    LAN
    > mutual
    > > > rights...
    my
    > > > ISP
    > using
    > > > the
    in
    > > > for
    > > >> > teleworkers....?
    to
    > > > mutual
    no
    > > >> > rights...
    > internet
    > > > via
    > > >> > a
    > mobile
    > need
    > > > to
    > > >> > do
    have
    > > >> > terminal
    etc.
    > > > What
    > > >> > do
    > remotely
    > > >> > from my
    > > >> >> > pocket pc?
    > > >> >> > Chris
Routers Networking Windows XP
