G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.work_remotely (More info?)
I have to keep on asking, as no replies yet, and after all,
this IS THE PLACE to get the CORRECT resoloutions, yesnp?
New PC setup 3 weeks ago, have been able to access it via
Remote Desktop AND with Remote assistance.
Behind Linksys router, DHCP assigned address
(192.168.1.101) for client PC, Firewall on PC with Remote
Desktp and Remote Assistance checked, and UPNP Framework
checked.
Upnp ON in router, etc., etc., etc.
Remember this all works, and worked until today.
Yesterday, I logged in via RDP and set his PC to use a
STATIC IP of 192.168.1.101, with appropiate Gateway
(192.168.1.1) and all relevant DNS pertaining to the ISP's
(Comcast).
In the router, I started the DHCP pool to begin at .102, as
the other PC in his house is at .100.
Then, after all of that, I attempted to login today, no
RDP, no RA, nothing. I had him reset PC NIC (TCP/IP) to
DHCP assigned as well as DHCP Automatic, no connection.
However, once I set it all back to a static setting as
outlined above, I was able to use RDP, revied all settings,
etc., and they are as outlined above.
No Remote Assistance though.
Question is, why did it all work, then stop when I made it
static, went back to Automatically assign, still no luck,
then back to static to at least get RDP, but still no RA?
In addition, I now get the BLACK SCEEN as outlined in
MULTIPLE previous posts (when attempting to connect via
RDP, I cannot connect to his desktop, it remains a black
screen, but as stated before, if I log in as Administrator,
then log out, then log back in as the user, it works.
Point being, it all worked 100% flawlessly until last night
when I made the NIC static instead of automatic, and also
do remember, it's a new 3 week old install that all worked
100% until this occurance as outlined above.
So, overview summary is:
1> Why no RA (it is enabled in Admin Tools/Comp. Mgmt/Local
Users and Groups/Users/Remote Assistance=ENABLED on ALL PC's)
2> Why if it all worked as an automatic, then not as
static, then only RDP when switched back to an static IP,
not automatic?
3> Why the black screen login, only to be successful when
logging in as admin, the log off, then login as user?
Like I said, it all worked, now it doesn't, as outlined above.
Thanks
checked.
(Comcast).
not automatic?
Thanks
