Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Remote through a dial up connection?
Archived from groups: microsoft.public.windowsxp.work_remotely (More info?)
Hello,
Is it possible to set up a remote connection to a workstation that has a
dial up connection. IOW, I need a workstation that has a dial up modem to
answer a call and allow me to connect to it??
Sponsored Links
Yes...
Configure RAS on Windows XP
Configure the desktop computer for incoming connections
1. Click Start, and then Control Panel.
2. Click the Network and Internet Connections icon and pick the Network Connections icon.
3. Double-click Make New Connection for the New Connection Wizard.
4. Select Advanced Connection under Network Connection Type and click Next.
4. Select Accept incoming connections and click Next.
5. Select the modem from the list of devices, and click Next.
6. Select either of the options for allowing Virtual Private Connections, and click Next.
7. Check the users you want to be able to authenticate when connecting to the desktop from the
device, and click Next.
8. Ensure the Internet Protocol (TCP/IP) check box is selected, click Next, and then Finish.
Call the phone number of the modem the PC is connected to from the remote PC...
Make sure your modem is setup for Auto Answer...
Al Jarvi (MS-MVP Windows Networking)
Please post *ALL* questions and replies to the news group for the mutual benefit of all of us...
The MS-MVP Program - http://mvp.support.microsoft.com
This posting is provided "AS IS" with no warranties, and confers no rights...
"Demus" <Me@somewhereelse.com> wrote in message news:N4qdnWymRfcT3nzcRVn-1A@comcast.com...
> Hello,
Reply to Anonymous
Thanks
"Sooner Al" <SoonerAl@somewhere.net.invalid> wrote in message
news:O2WntDm9EHA.3840@tk2msftngp13.phx.gbl...
> Yes...
> Connections icon.
> Next.
> PC...
> rights...
>> Hello,
Reply to Anonymous
Ok, I can connect to the remote computer and browse its shares but cannot
get remote desktop to work.
The remote computer is also running Novell, is there any problems with rdc
and novell??
Just wondering because Novell changes the login.
> Yes...
> Connections icon.
> Next.
> PC...
> rights...
>> Hello,
Reply to Anonymous
I have absolutely no experience with Novell since I am strictly a home user, so I can't say...
Hopefully someone else can jump in and comment on that issue...
"Demus" <Me@somewhereelse.com> wrote in message news:VcWdnRwLyfZ7b3_cRVn-tA@comcast.com...
> Ok, I can connect to the remote computer and browse its shares but cannot get remote desktop to
> work.
> The remote computer is also running Novell, is there any problems with rdc and novell??
>> Yes...
>>> Hello,
>>> Is it possible to set up a remote connection to a workstation that has a dial up connection.
>>> IOW, I need a workstation that has a dial up modem to answer a call and allow me to connect to
>>> it??
Reply to Anonymous
ok, well lets just say its not novell. is there anything else that would
cause rdc to not work. Any services being disabled or registry entries??
There are some things I did to the pc but I didnt think they affected rdc in
anyway, just curious.
news:OUIrzt19EHA.2632@TK2MSFTNGP10.phx.gbl...
>user, so I can't say... Hopefully someone else can jump in and comment on
>that issue...
> rights...
>> rdc and novell??
>>> Yes...
>>> Next.
>>> remote PC...
>>> rights...
>>>> Hello,
>>>> a dial up connection. IOW, I need a workstation that has a dial up
>>>> modem to answer a call and allow me to connect to it??
Reply to Anonymous
See the troubleshooting section of this page for some help...
http://theillustratednetwork.mvps. [...] oting.html
You did enable Remote Desktop on the PC, correct?
http://www.microsoft.com/resources [...] m_huxe.asp
Is the PC your trying to reach on a LAN? Is so, test from another PC on the same LAN to see if you
can connect with RD...
"Demus" <Me@somewhereelse.com> wrote in message news:Aumdnc_2VdjwYX_cRVn-3Q@comcast.com...
> ok, well lets just say its not novell. is there anything else that would cause rdc to not work.
> Any services being disabled or registry entries?? There are some things I did to the pc but I
> didnt think they affected rdc in anyway, just curious.
>>> work.
>>>> Yes...
>>>> the
>>>> us...
>>>>> Hello,
>>>>> it??
Reply to Anonymous
Got it going! Terminal services was disabled.
Thanks.
news:uUGnvG29EHA.3700@tk2msftngp13.phx.gbl...
> the same LAN to see if you can connect with RD...
> rights...
>>>that issue...
>>> rights...
>>>> cannot get remote desktop to work.
>>>> rdc and novell??
>>>>> Yes...
>>>>> click Next.
>>>>> remote PC...
>>>>> rights...
>>>>>> Hello,
>>>>>> has a dial up connection. IOW, I need a workstation that has a dial
>>>>>> up modem to answer a call and allow me to connect to it??
Reply to Anonymous
Thanks for the feedback...
Glad to hear its working for you...
"Demus" <Me@somewhereelse.com> wrote in message news:aLqdne7nXobL0nncRVn-ow@comcast.com...
> Thanks.
>> rights...
>>>>that issue...
>>>> rights...
>>>>> rdc and novell??
>>>>>> Yes...
>>>>>> click Next.
>>>>>> remote PC...
>>>>>> rights...
>>>>>>> Hello,
Reply to Anonymous
There are 1219 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
