Tom's Hardware > Forum > Graphic & Displays > TV/Video Cards > Help, Encore project switch to PAL from NTSC
Forum Graphic & Displays : TV/Video Cards - Help, Encore project switch to PAL from NTSC
Archived from groups: rec.video.desktop (More info?)
I have created a DVD project inside Adobe Encore. It is a full length
65 min project. What I want to do now is save this project as an
image file but want to switch the format to PAL.
When I stared the project, Encore asked me which format I want. I
chose NTSC because that is what I needed. Now I have some European
friends that want a copy.
Is there a way to tell Encore to save the IMG file as PAL even though
it started out as a NTSC setting? Lotta work putting all the many
pieces together and getting it to work, I don't want to start from
scratch again just for a PAL format.
Sponsored Links
You might also check the Encore specialty forum
http://www.adobeforums.com/cgi-bin/webx?14@@.1de98ec0
John Thomas Smith
http://www.direct2usales.com
http://www.pacifier.com/~jtsmith
Reply to Anonymous
There are 1138 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
