G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.work_remotely (More info?)
I am attempting to use Remote desktop to connect to a computer that runs a
presentation constantly. What I need to be able to do it remotely connect to
it, using remote desktop or the like, and then once I am finished, leave the
computer unlocked, with the display still showing the presentation. When I
disconnect from the Remote Desktop, it then locks the computer and says the
classic "CTL ALT DEL" login screen.
Is there a way to prevent this from happening?
