Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Remote connection on a LAN
Archived from groups: microsoft.public.windowsxp.work_remotely (More info?)
Hi all, Really sorry but this is another one of those Newbee Questions :-)
I have a small 3 computer network i use a standard ethernet switch to
connect the computers, this worked fine for file sharing and also Remote
Desctop connection. however i rcently got my self a Tablet Pc with wireless
capability so to make use of this i got rid of the standard swich and
replaced it with a Netgear cable/DSL wirless Router (mobel No MR814v2) this
had 4 ethernet conections and the wirless capability. File sharing is fine
but i can no longer use the remote connection :-(
I gather it is something to do with Port forwarding, but i am not sure how
this works or what ports to forward.
when i go to the port forwarding feature on the routers software, i am able
to add a custome service it asks me for
Service Name
Starting Port
Ending Port
Server IP Address
Any help you could give me with this proble would be greatly appreciated
Thanks
Martin
Sponsored Links
See these pages for help...
http://theillustratednetwork.mvps. [...] oting.html
http://theillustratednetwork.mvps. [...] PC_RD.html
Al Jarvi (MS-MVP Windows Networking)
Please post *ALL* questions and replies to the news group for the mutual benefit of all of us...
The MS-MVP Program - http://mvp.support.microsoft.com
This posting is provided "AS IS" with no warranties, and confers no rights...
"martin" <mhayes@europe.sial.com> wrote in message
news:3886D19A-3389-44E0-A634-0D0DFA571489@microsoft.com...
> Service Name
> Starting Port
> Ending Port
> Server IP Address
> Thanks
> Martin
Reply to Anonymous
Hi,
The info was very very useful !!! Thanks
I am 90 % done just one last problem that i am hoping you will be able to
help me with :-)
I am now able to remote connect to any of my machines apart from one, this
is the main computer. When i use the port Query it says that this machine is
TCP port 3389 (unknown service): NOT LISTENING
How do i make this computer Listen :-)
Any help would be FAB
Thanks
Martin
> > Service Name
> > Starting Port
> > Ending Port
> > Server IP Address
> > Thanks
> > Martin
Reply to martin
Did you enable Remote Desktop on that particular PC?
news:E13BE2C4-4DFE-4D0A-A190-32187CBBF294@microsoft.com...
> Hi,
> help me with :-)
> Thanks
> Martin
>> > Service Name
>> > Starting Port
>> > Ending Port
>> > Server IP Address
>> > Thanks
>> > Martin
Reply to Anonymous
Hi,
Yep i have enabled Remote Desktop.
And the computer has user accounts with passwords.
The Winxp Firewall has an exception set for Remote Desktop (port 3389).
Would it matter that this pc is WinXp sp2 ?
This is also the pc that i have used to set up the router (although the port
forward is to a different machine).
Thanks Lots for your help !!!!!
Martin
> > Hi,
> > help me with :-)
> > Thanks
> > Martin
> >> > Service Name
> >> > Starting Port
> >> > Ending Port
> >> > Server IP Address
> >> > Thanks
> >> > Martin
Reply to martin
So are you testing connection to this one particular PC over the local LAN or from a remote
location?
If its from a remote location check port forwarding on the router to verify the correct ports are
being forwarded to the correct static LAN IP.
If your testing on your local LAN are you calling the correct static local LAN IP?
news:C6AF7C88-40D6-449C-9A72-CD25C773258A@microsoft.com...
> Hi,
> Martin
>> > Hi,
>> > help me with :-)
>> > Thanks
>> > Martin
>> >> us...
>> >> > Service Name
>> >> > Starting Port
>> >> > Ending Port
>> >> > Server IP Address
>> >> > Thanks
>> >> > Martin
Reply to Anonymous
There are 1307 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
