Tom's Hardware > Forum > Graphic & Displays > TV/Video Cards > AVI audio track extraction
Forum Graphic & Displays : TV/Video Cards - AVI audio track extraction
Archived from groups: rec.video.desktop (More info?)
Hi, I'm just getting started on audio and video editing and have some
rudimentary tools for the purposes. I was wondering if anyone knows if
AVI files store audio tracks separately of each other. I've come across
a video file with the default audio layered underneath some dubbing.
Would the dubbing be layered over the main layer in a manner that would
make it possible to extract it? Also does anyone know of a piece of
software that would manage this task if it's possible? Thanks in advance.
Kevin Reid
Sponsored Links
On Mon, 07 Mar 2005 17:42:55 GMT, mahalliner
AVI = AudeoVideoInterleave = alternating frames of audio/video
Everything is all mixed in one file (no, I don't know the tech
details, just that everything is in one the file)
Have you looked at the TOOLS section of videohelp.com ?
John Thomas Smith
http://www.direct2usales.com
http://www.pacifier.com/~jtsmith
Reply to Anonymous
On Mon, 07 Mar 2005 10:35:26 -0800, John Thomas Smith
>John Thomas Smith
virtualdub or virtualdubmod can tell you the number
of audio channels and save them to WAV if you wish.
In the case you mention above,it's highly likely
that the dubbing and original audio are the same
track, unfortunately.
On the other hand, some foreign language mpg files
have the original sound on one channel, and the dubbed
on the other. Two separate mono soundtracks.
When it's made into a vcd, you can choose which one
to hear.
Dave
Reply to Anonymous
There are 1289 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
