Archived from groups: microsoft.public.windowsxp.work_remotely (More info?)
I am able to stretch the remote desktop a bit using command line arguments
to launch remote desktop E.g mstsc.exe /v:serverip /w:2048 /h:768. But it
maxes out at 1600 pixels horizontally - not the 2048 I want. Anyone know
how to get the width right?
> arguments to launch remote desktop E.g mstsc.exe /v:serverip /w:2048
> /h:768. But it maxes out at 1600 pixels horizontally - not the 2048
> I want. Anyone know how to get the width right?
> Local and remote systems are running XP SP2
> Ref:
> http://www.microsoft.com/windowsxp [...] _mstsc.asp
Remote Desktop does not support dual monitor setups/resolutions.
<- Shenan ->
The information is provided "as is", it is suggested you research for
yourself before you take any advice - you are the one ultimately
responsible for your actions/problems/solutions. Know what you are
getting into before you jump in with both feet.
since remote desktop does not support 2 monitors, you can either use
the application sharring feature in netmeeting, or VNC www.realvnc.com
kenny
"m6rk" <mjm@110.net> wrote in message
news:eXp3rckIFHA.3696@tk2msftngp13.phx.gbl...
> Ref:
> http://www.microsoft.com/windowsxp [...] _mstsc.asp >
If your going to use VNC then at least use UltraVNC with its encryption plug-in or run VNC through a
VPN or SSH tunnel if this connection is over the public internet... The native VNC data stream is
*NOT* encrypted and is therefore a potential and probable security risk...
Please post *ALL* questions and replies to the news group for the mutual benefit of all of us...
The MS-MVP Program - http://mvp.support.microsoft.com This posting is provided "AS IS" with no warranties, and confers no rights...
"Kenny S" <hotmail@coldmail.com> wrote in message news:eBd8N%23yIFHA.572@tk2msftngp13.phx.gbl...
> the application sharring feature in netmeeting, or VNC www.realvnc.com >
> kenny
[snip]
> plug-in or run VNC through a VPN or SSH tunnel if this connection is over
> the public internet... The native VNC data stream is *NOT* encrypted and
I had checked out VNC in general, unfortunately it does not support dual
monitor either.
