G
Guest
Guest
Archived from groups: rec.video.desktop (More info?)
Hello,
I am having problems capturing video on my mom's computer, using
Videowave 7 Professional. Here's the play by play:
Plug DV JVC camera into firewire port on the back of the computer.
Launch VW7, select "Capture Video."
Select "DV JVC" from list of resources.
The capture window comes up, the camera starts and goes into pause
mode, the video showing on the camera's LCD screen. The problem is
that the video from the camera is not displaying the capture preview
screen in VW7.
I have installed VW7 and successfully completed all the above steps on
my own computer. For some reason it just doesn't work on my mom's.
I know that her computer is recognizing the camera initially, because
it gives you that stupid Windows XP action prompt, plus the pre-roll
control VW7 seems to have on the camera when capture is launch. Just
no preview screen or ability to control the camera from that point on.
I figure that there must be something with her computer that is
interfering, such as a driver or something, but I really don't know
much about troubleshooting this kind of thing.
If anyone has any suggestions, or has experienced this problem, please
help me out.
Here are the computer specs:
Problem computer:
HP Pavillion a620n
3200+ AMD athlon
512 SDRAM
Camera: JVC GRD33U (mini-DV, from Wal-Mart)
Computer that worked:
HP Pavillion a420n
3000+ AMD athlon
512 SDRAM
Thanks!
Morgan
Hello,
screen in VW7.
help me out.
Problem computer:
HP Pavillion a620n
3200+ AMD athlon
512 SDRAM
HP Pavillion a420n
3000+ AMD athlon
512 SDRAM
Thanks!
Morgan
