Archived from groups: rec.video.desktop (More info?)
I have 865PE/G Neo2 series mobo and the microphone is connected to the mic jack.
I've set the recording volume for microphone all the way up in:
Volume Control->Options->Properties->Recording->OK
The mixer device is on-board Realtek AC97.
This is the usual steps for question like mine. Unfortunately with this mobo the
recording volume is too low.
Is there anything else I can do? I had the same mic (el cheapo computer mic) on a
couple of other systems and above settings helped getting the recording volume
up.
What can I try next. Other sounds work just fine.
up.
