G
Guest
Guest
Archived from groups: microsoft.public.windows.networking.wireless (More info?)
I have a home wifi network with a win2000 desktop, a WinXP SP2 notebook, and
an HP 2510 wireless network printer. Recently, out of the blue, I am unable
to print and get the following message:
"The print spooler was unable to connect to your printer. This can be
caused by your printer being turned off, the cable being unplugged, or being
connected to a VPN, which will block you access to the local network. Your
document will print when the printer becomes available."
None of the suggested causes exist. I've noticed that I can print from the
notebook only if the desktop is off but can't print from the desktop whether
the notebook is on or off. I am suspecting IP addresses.
The printer is currently at IP 192.168.1.51 and the desktop is at
192.168.1.52. IPs are dynamically assigned. However, when I do "ping -a
192.168.1.52" I get a message "Pinging HP2510 [192.168.1.52] with 32 bytes
of data:" which is the same as I get when I ping the printer. Is my desktop
confused about IP addresses and thinks that its own IP is the printer IP?
Or is the -a option just flaky?
Any help would be much appreciated.
