Archived from groups: rec.video,rec.video.desktop (More info?)
On my WinXP PC I used to have two drives: A DVD-R and a CD-RW, both of
which worked fine. I recently replaced the CD-RW with a DVD-RW. Now the
DVD-R is unstable: Sometimes it can read and play DVDs, and some other
times the whole system hangs when I insert the disk. I think the
problem is always caused by the same disks. The new drive however reads
and plays all disks. Any ideas what could be causing this?
Before installing the new drive did you change the jumper to match the one
being replaced? One is master and one is slave. Drives usually ship as
master.
<jramaley@iname.com> wrote in message
news:1112160999.340368.86570@z14g2000cwz.googlegroups.com...
> thanks
the one
as
> master.
Yes, I did. Windows XP does see the drive anyway. The problem is when I
insert most DVDs!
Check the DMA on the IDE channel. Some DVD-ROM drives needed to use DMA but
is not really necessary for DVD-R/RW drives. Mine all run fine on regular
old PIO.
news:1112211780.756938.301150@g14g2000cwa.googlegroups.com...
> the one
> as
>> master.
> insert most DVDs!
I thought you no longer have to do these things because XP is Plug And
Play. Someone please confirm!
marks542004@yahoo.com wrote:
> did you properly remove the drive replaced ?
> the best sequesnce is (in my opinion)
> remove the drivers for the device.
> remove the device
> reboot the system
> check the device and drivers are gone.
> install the new hardware
> start the system
> new hardware detected
> load drivers
> etc.
> If you just swap in a new device you can get errors in the registry
> because the old device was not properly deinstalled.
jramaley wrote ...
> is Plug And Play. Someone please confirm!
"Plug And Play" was the original marketing name.
Most of us call it "Plug and Pray" and many reserve even
stronger and fouler language for it. It works great when it
works. But when it doesn't, you have do do all manner of
screwy things (like this) to work around it. If there were
only some way of turning it off.
"I hate it when my computer thinks it is smarter than me."
In article <1112765933.743022.267630@f14g2000cwb.googlegroups.com>,
jramaley@iname.com says...
> Subject: Re: DVD ROM drive problem after installing DVD-RW
> From: jramaley@iname.com
> Newsgroups: rec.video, rec.video.desktop
> > remove the device
> > reboot the system
> > start the system
> > load drivers
> > etc.
You have to do these things because of plug and play.
_________________________
Chris Phillipo - Cape Breton, Nova Scotia
http://www.ramsays-online.com
Make sure the new DVD RW is NOT connected to the old DVR. If you have cable
space...connect each one to a Hard drive cable making each DVD device a
slave. This way there will be no conflicts and you'll copy to the DVD RW
from the DVD rom directly<jramaley@iname.com> wrote in message
news:1112766087.619912.290080@o13g2000cwo.googlegroups.com...
> Don't forget that the new DVD-RW drive is working fine. It's the old
> DVD-ROM drive that has the problem, which used to work!
