Tom's Hardware > Forum > Computer Peripherals > Digital Cameras > Problems with Panasonic Lumix FZ5-EB and SD Cards
Forum Computer Peripherals : Digital Cameras - Problems with Panasonic Lumix FZ5-EB and SD Cards
Archived from groups: alt.comp.periphs.dcameras (More info?)
I recently bought a Panasonic Lumix FZ5-EB (does anyone know the
difference between a FZ5-EB and a FZ5-BB?) and found that it would
not recognize a 1 GB SD card produced by Corsaire.
I then bought a 512 Mb SD card produced by PNY but it cannot format
this either.
Both of these cards work fine in other cameras. Has anyone else had
this problem, or does anyone know a way around it.
Many thanks,
John
Posted using the http://www.hardwareforumz.com interface, at author's request
Articles individually checked for conformance to usenet standards
Topic URL: http://www.hardwareforumz.com/Digi [...] 60698.html
Visit Topic URL to contact author (reg. req'd). Report abuse: http://www.hardwareforumz.com/eform.php?p=306551
Sponsored Links
> *From:* Spudz <UseLinkToEmail@HardwareForumz.com>
> *Date:* 18 Aug 2005 18:38:55 -0400
> Has anyone else had this problem, or does anyone know
> a way around it.
If nobody can help you could do worse than registering here...
http://forums.dpreview.com/forums/ [...] 033&page=1
Andrew McP
Reply to Anonymous
> this either.
> Many thanks,
> John
since it's a new camera, i'd take it to a service and let them find out the
problem, but i'd say it's camera's fault...
I only hope that this EB and BB difference isn't that EB is old version
which takes only up to 256M cards... :-(
You could also try to find firmware update if that helps...
Reply to Anonymous
There are 1153 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
