Archived from groups: microsoft.public.windowsxp.work_remotely (
More info?)
Hi Colin,
Thanks for your post.
My understanding on this issue is that when you attempt to offer remote
assistance, you receive the message "Permission Denied" also if anyone
tries to offer you remote assistance they receive the same message. You
have tried the Q310629 and no change. If I have misunderstood your
concern, please feel free to let me know.
Based on my research, the problem can occur if DCOM is not enabled on the
computer.
You can enable DCOM through the following registry value:
HKEY_LOCAL_MACHINE\Software\Microsoft\Ole
set EnableDCOM to Y
You can also enable/disable DCOM through DCOMCNFG.EXE. See KB article
825750 for more information.
RELATED KNOWLEDGE BASE ARTICLES
825750 How to Disable DCOM Support in Windows
http://support.microsoft.com/?id=825750
ADDITIONAL INFORMATION AND RECOMMENDATIONS
DCOM is a protocol that enables software components to communicate directly
over a network. Previously called "Network OLE," DCOM is designed for use
across multiple network transports, including Internet protocols such as
HTTP.
For more information about DCOM, visit the following Microsoft Web site:
http://www.microsoft.com/com/tech/dcom.asp
Verify DCOM permissions
1- Select Start/Run.
2- Type DCOMCNFG.
3- Select the Default Properties tab.
Confirm the settings enabled.
"Default Authentication Level" should be "Connect".
"Default Impersonation Level" should be "Identify".
4- Select the Default Security tab.
Select the "Default Access Permissions" "Edit Default" button.
Ensure the "Registry Value Permissions" list is either empty (with NO
accounts defined), or, if accounts are defined, the System account MUST be
included.
If the list is empty or unchanged, select "Cancel".
If the list is populated to include the System account, select "O.K."
5- Select the "Default Launch Permissions" "Edit Default" button. And
ensure the
"Registry Value Permissions" list contains a minimum of the following:
\\\Administrators, Interactive, System.
6- Select the Default Configuration Permissions Edit Default button. Ensure
the
Registry Value Permissions list contains a minimum of the following:
\\\Administrators
\\\Power Users
\\\Users
\\\Creator Owner
\\\Everyone
\\\System
7- Select the Applications tab.
Select the {000C101C-0000-0000-C000-000000000046} application properties
(this is the MSIServer application).
Ensure the Authentication Level is set to Default on the General tab.
Select the Security tab.
Ensure Use default access permissions, Use default launch permissions and
Use default configuration permissions are selected. If not, ensure the
System account is defined with all permissions.
8- Restart the system.
HTH. If you have any other new findings or questions, please feel free to
let me know. I'm very glad to help you.
Thanks & Regards
Amanda Wang [MSFT]
Microsoft Online Partner Support
Get Secure! -
www.microsoft.com/security
When responding to posts, please "Reply to Group" via your newsreader so
that others may learn and benefit from your issue.
