Tom's Hardware > Forum > Graphic & Displays > TV/Video Cards > DVD Shrink ripping VOBs with no audio; solution?
Forum Graphic & Displays : TV/Video Cards - DVD Shrink ripping VOBs with no audio; solution?
Archived from groups: alt.video.avid_editors,alt.video.dvd.software,comp.publish.cdrom.software,rec.video.desktop,alt.video.dvd (More info?)
I have Vegas Video 4 and I have the plugin that will allow it to deal
with VOB files. Great because I'm buying workout DVDs now instead of
VHS ones so that I can create my own customized workouts.
I just tried ripping two of my new DVDs and then taking the VOB files
into V V 4 only to have no audio. I was able to do this a few days
ago so don't know why no audio waveform today in V V 4.
I have the AC3 option checked under the Compression tab in DVD Shrink
but nothing. Just to make sure, I also tried DVD Shrink re-author
with the subfolders for Video_TS and Audio_TS when backing up, and in
the Audio_TS the folder is empty. I don't know if having that folder
empty has any bearing on this problem at all, but thought I'd mention.
The reason why DVD Shrink is so important for me is that I can
re-author and pick parts out that I need visually. From these main
workout DVDs, I'm creating specialized "targetting" ones, as I refer
to them. I used to do this with my bought VHS workouts using 2 VCRs.
Needless to say, so much easier with DVDs and a computre but it's no
good if I can't get the audio because I do need it half the time for
this. Alternative is to rip entire DVD to mpg when I need the audio
from the workout itself and am not replacing it with my own music mix,
and then cut it up but, man, I really don't want to go that route.
Any ideas on what is wrong? I'm using DVD Shrink v3.2.0.15. I've
just spent (wasted?) two hours on searches on the net looking for "no
audio" problems related to DVD Shrink and nothing that has come up
deals with the problem I'm having.
Thanks.
Sponsored Links
On Fri, 08 Apr 2005 13:04:32 -0400, Traveller
>Thanks.
Ah, very weird. Because of what I'd read on the net, after posting
this, decided to see if my WMP6 (with codecs) could play the VOB file.
It could once I'd renamed to MPG. Yet V V 4 isn't showing waveform
and renders with no audio.
Very weird.
Reply to Traveller
- 0 +
Have you tried playing the files that DVD Shrink creates with a
software-based DVD player, or even the latest Windows Media Player? If audio
is heard that way then you can at least narrow this problem down to the
editing software that you're trying to use.
The AUDIO_TS folder is empty in virtually all DVDs.
Reply to bill
In article <vndd51h34a89794lv95gomekvkjiqplq8v@4ax.com>,
Jamboree@SpamMailNo.com says...
> Thanks.
Your vegas may not have the ac3 plugin. You could demux and run the
resulting .ac3 file through besweet if you don't want to get it.
Reply to Anonymous
> Thanks.
If you were seeing the audio from a DVD in Vegas, it was encoded as a PCM
file. Most DVDs these days have the audio encoded as an AC3 file which very
few NLEs, Vegas included, will import. The workaround is to use an app like
AC3Decode found at http://www.users.on.net/~rsobon/ac3dec.html
Make sure to select "convert to wav" under Mode and "PCM-48,000 KHz, 16 bit
audio" as the output codec.
Mike
Reply to Anonymous
On Fri, 8 Apr 2005 19:49:32 -0400, "Mike Kujbida"
>> Thanks.
Thanks for everyone's input! Since an older DVD does have sound in
Vegas 4, thought it might be an encryption problem on newer DVDs.
Thie above sounds more probable.
I'll give all the advice a try and report back.
Thanks.
Reply to Traveller
This topic has been closed by Mousemonkey
------------------------------ [:mousemonkey:1] http://img29.imageshack.us/img29/5041/vr2009champ.jpg
Reply to mousemonkey
There are 901 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
