Archived from groups: microsoft.public.windowsxp.work_remotely (More info?)
I have XP Pro. I need to use RDC but When I go on Start>All Programs>
Accessories, There is no folder "Communications" and no link for Remote
Desktop connection...
And When I try to install it from the XP pro installation CD using the
Option "Perform additional Task" and then "Set up Remote Desktop Connection".
It starts installation but ends up with this error message "Remote Desktop
connection can not be installed because your operating system already has a
built-in version. See more Programs]Accessories\Communications\Remote Desktop
Connection on your Start Menu"
and When I click the Accessories, I do not see the folder "Communication".
I would be grateful if some one could help me in this regard,
Thanks
Waseem
The file is named "mstsc.exe" and is, or should be, in the "C:\Windows\System32" folder. To add the
short cut to the "Start -> All Programs -> Accessories -> Communications" menu navigate to the
"C:\Documents and Settings\All Users\Start Menu\Programs\Accessories\Communications" folder,
right-click on empty space and select New -> Short Cut. Add the file name using the browser and name
it "Remote Desktop Connection".
....or...
Go to "Start | Run" and type mstsc in the command line window.
Al Jarvi (MS-MVP Windows Networking)
Please post *ALL* questions and replies to the news group for the mutual benefit of all of us...
The MS-MVP Program - http://mvp.support.microsoft.com This posting is provided "AS IS" with no warranties, and confers no rights...
"Waseem" <Waseem@discussions.microsoft.com> wrote in message
news:7B3604B0-417B-47B6-8646-D5B5B5C6E434@microsoft.com...
> Thanks
> Waseem
I'm attempting to set up RDP in a windows xp pro environment. There is a
windows 2000 domain controller on the network. I've setup rdp on a few of the
xp pro machines and I get "The local policy of this system does not allow you
to log on locally".
I've modified the security policy on the machines to allow log on locally.
I've done the same thing on the domain controller in the domain security
policy. I've also added users to the rdp users group locally on the machines.
I still get the same log on message. I've done this before with no problem in
windows xp rpo/ win 2003 server environments.What have I missed?
Thanks in advance.
"Robert L [MS-MVP]" wrote:
> do search mstsc.exe which is located in windows\system32. Then copy a shortcut. For more and other information, go to http://howtonetworking.com. >
> Don't send e-mail or reply to me except you need consulting services. Posting on MS newsgroup will benefit all readers and you may get more help.
> Bob Lin, MS-MVP, MCSE & CNE
> How to Setup Windows, Network, Remote Access on http://www.HowToNetworking.com > Networking, Internet, Routing, VPN Troubleshooting on http://www.ChicagoTech.net > This posting is provided "AS IS" with no warranties.
> I recommend Brinkster for web hosting!
> "Waseem" <Waseem@discussions.microsoft.com> wrote in message news:7B3604B0-417B-47B6-8646-D5B5B5C6E434@microsoft.com...
> Thanks
> Waseem
