Yes No
Ads
Tom's Hardware > Forum > Windows XP > General Discussion > Remote Deskop Connection works ok, then disconnects, can't..
Forum Windows XP : General Discussion Remote Deskop Connection works ok, then disconnects, can't..
Archived from groups: microsoft.public.windowsxp.work_remotely (More info?)
I broke my elbow a few weeks ago, so I have been accessing my home
desktop using RDC from my laptop (both XP Pro). This worked really well
for a couple of weeks, but recently I've found that if my connection
drops for some reason (hibernation of laptop, etc.), I have to reboot
the machine I'm connecting to before I can connect again. The error I
get is "Remote Desktop Disconnected", and the text in the box says "The
client could not establish a connection to the remote computer" with a
bunch of choices such as remote connections not enabled, maximum # of
connections exceeded at remote computer, and a network error occurred.
My network is otherwise working fine. I can ping the remote system, and
if I reboot it, I can connect again. Any suggestions? Is it possible
that Windows is not closing the connection properly? Is there a way to
increase the maximum # of connections on the remote system? Please, no
advice on checking to see if RDC is working properly; as I said, it
worked fine for a couple of weeks and still works ok now, except once I
get disconnected.
Bill
Reply to bill
There are Group Policies that define idle session timeouts and when to disconnect them...
Have you looked at the Group Policies. Run gpedit.msc on the Remote Desktop host machine and
navigate to the Local Computer Policy | Computer Configuration | Administrative Templates | Windows
Components | Terminal Services | Sessions policies.
Al Jarvi (MS-MVP Windows Networking)
Please post *ALL* questions and replies to the news group for the mutual benefit of all of us...
The MS-MVP Program - http://mvp.support.microsoft.com
This posting is provided "AS IS" with no warranties, and confers no rights...
"Bill" <billrubin@prodigy.net> wrote in message news:ul7qDJTSFHA.904@tk2msftngp13.phx.gbl...
>I broke my elbow a few weeks ago, so I have been accessing my home desktop using RDC from my laptop
>(both XP Pro). This worked really well for a couple of weeks, but recently I've found that if my
>connection drops for some reason (hibernation of laptop, etc.), I have to reboot the machine I'm
>connecting to before I can connect again. The error I get is "Remote Desktop Disconnected", and the
>text in the box says "The client could not establish a connection to the remote computer" with a
>bunch of choices such as remote connections not enabled, maximum # of connections exceeded at
> My network is otherwise working fine. I can ping the remote system, and if I reboot it, I can
> connect again. Any suggestions? Is it possible that Windows is not closing the connection
> properly? Is there a way to increase the maximum # of connections on the remote system? Please, no
> advice on checking to see if RDC is working properly; as I said, it worked fine for a couple of
> weeks and still works ok now, except once I get disconnected.
> Bill
Reply to Anonymous
- 0 +
Thanks for the pointer. I checked and none of those are configured,
which should mean that I don't get disconnected at all. Is it possible
that if I have something else running that has a lot of connections that
RDC could be unable to get the resources to create the connection when I
try to reconnect?
Bill
Reply to bill
Bill:
Are you running Spy Sweeper on the remote computer? If so, please read my
post in this newsgroup on April 26:
news:<116tt86i8dkscda@corp.supernews.com>
Hope this helps.
>using RDC from my laptop (both XP Pro). This worked really well for a
>couple of weeks, but recently I've found that if my connection drops for
>Desktop Disconnected", and the text in the box says "The client could not
>establish a connection to the remote computer" with a bunch of choices such
> I reboot it, I can connect again. Any suggestions? Is it possible that
> Windows is not closing the connection properly? Is there a way to increase
> the maximum # of connections on the remote system? Please, no advice on
> a couple of weeks and still works ok now, except once I get disconnected.
> Bill
Reply to Anonymous
- 0 +
Interesting.. yes, I am running Spy Sweeper on that machine. I tried
shutting it down but still could not reconnect but will definitely look
into that. BTW, there is a beta of the new version of Spy Sweeper
available for public use, go to the "update program" option and it will
pull up the page. I wonder if they fixed the problem there.
Bill
Sid Joyner wrote:
> Bill:
> Hope this helps.
>>Bill
Reply to bill
There are 2063 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Microsoft Updates - In Triplicate !
By Hawkeye22, 1 day ago:
They won't show up in add/remove programs because they were superceded by a different...
Best offers
Top experts
