G
Guest
Guest
Archived from groups: rec.video.desktop (More info?)
I am planning on building a Media Center for my living room and I am
having problems finding a capture card, actuall the card may not exist.
Most capture cards that I have come across so far have built in tuners
for cable or antenna; that allow you to change channels and record tv
programs onto the PC. Obviously these capture cards/TV tuners will not
work with a Satellite receiver since the channel needs to be chanaged
on the receiver. I would think that there would be a capture card out
there that has a IR transmitter that can send IR commands to specified
satellite receivers to change channels at a specific time to record TV
programs. Is there such a device out there?
Thanks for any help.
