Archived from groups: microsoft.public.windowsxp.work_remotely (
More info?)
The web based method, using IIS, still requires you to port forward the RDP protocol to each PC
through the router. You simply can not get around that. You then need to use Jeffrey Randow's
(MS-MVP) modified default.htm file on the IIS server so you can dynamically change the port your
calling with...
For information on how to setup port forwarding to multiple PCs behind a firewall/NAT/router look at
this page...
http://theillustratednetwork.mvps.org/RemoteDesktop/Multiple_PC_RD.html
To download the modified default.htm file from here...
http://www.remotenetworktechnology.com/LinkClick.aspx?link=revised_rdwc.zip&mid=365
Make a backup of the original default.htm file first just to be safe...
As you can see, using the web based method adds complexity to the process. It may be easier for you
to simply access the PCs via either a VPN or SSH tunnel. Personally I use the SSH tunnel method to
access one or more XP Pro/Home boxes using either XP Pro Remote Desktop or UltraVNC for XP Home
machines...
http://theillustratednetwork.mvps.org/RemoteDesktop/SSH-RDP-VNC/RemoteDesktopVNCandSSH.html
Other SSH and Remote Desktop information...
http://www.bluestream.org/Networking/SSHTunnelRDP.htm
http://www.dslreports.com/faq/vnc
PPTP VPN help...
http://www.onecomputerguy.com/networking/xp_vpn_server.htm
http://www.onecomputerguy.com/networking/xp_vpn.htm
Al Jarvi (MS-MVP Windows Networking)
Please post *ALL* questions and replies to the news group for the mutual benefit of all of us...
The MS-MVP Program -
http://mvp.support.microsoft.com
This posting is provided "AS IS" with no warranties, and confers no rights...
"Benjy" <Benjy@discussions.microsoft.com> wrote in message
news:19997058-ECD3-4F30-BACC-6529ECF52551@microsoft.com...
> Thanks, but I've already done that. I noticed a strange thing though, (after
> I posted) if I leave the server name blank and click on connect, a black
> screen opens with the external ip of my router on the title. when I login on
> the next screen using an account on the machine where IIS is running, I can
> use it normally. But I cant connect to any other machine on my network even
> though remote desktop is enabled on them. Do I need to set up all the sytems
> as hosts using different port numbers for IIS for each one of them? That
> would be a big task.
> "Sooner Al [MVP]" wrote:
>> You need both TCP Port 80 (IIS) and TCP Port 3389 (Remote Desktop) forwarded through the router
>> to
>> the static LAN IP of the IIS server and PC your trying to connect to. Call using the public IP of
>> the router, ie. the IP assigned by your ISP.
>> news:663388EF-14C6-4B78-B9F0-B4E16427A426@microsoft.com...
>> > I've set up Remote Desktop web connection and it works well when I use it
>> > using a local ip address within the network. However when I connect from
>> > outside the network, I get to the main screen where the Active X loads. when
>> > I click connect though, after some time I get an error message saying that
>> > maybe remote desktop connection is not enabled on the machine or there is
>> > some network problem and I should try again later. I use an Aztech DSL turbo
>> > 900 router which has NAT enabled and I've tried opening up all the ports in
>> > the posts. I suspect the problem lies with the router configuration. Can
>> > anyone help?
