Archived from groups: rec.video,rec.video.desktop (More info?)
Hi all,
I'm using my TRV38 as a webcam, seems to work just fine so long as I keep it
"active". If you don't it times out after a few minutes. I don't know
exactly what the duration is but it does time out. I'm streaming to my
desktop via usb.
Does anyone know why it's doing this? I can't seem to find a menu option to
toggle the timeout either.
It should stay on indefinitely if you don't keep a tape in it.
"Kevin" <kevin@xxvwkebxyz.com> wrote in message
newsTf9e.2275$r53.268@attbi_s21...
> Hi all,
it
> desktop via usb.
to
> Thanks,
> Kevin
That is the secret with all the Sony's I have worked with.
With a tape in it, it times out, no tape, it will stay on all
the time.
mikey
"PTravel" <ptravel@ruyitang.com> wrote in message
news:3clgsuF6nppl2U1@individual.net...
> > Hi all,
keep
> it
> > desktop via usb.
option
> to
> > Thanks,
> > Kevin
Thanks guys! looks like it's fixed.
BTW, do you have any recos on good webcam software? Something that I can
keep on for hours. So far I've only tested with AOL and MSN IM.
Thanks,
Kevin
"HerHusband" <unknown@unknown.com> wrote in message
news:Xns963E45247CCD4herhusband@216.196.97.136...
> Kevin,
> > keep it "active". If you don't it times out after a few minutes.
> Removing the tape should prevent the camcorder from shutting off after 5
> minutes or so.
> You may also need to disable the "screensaver" mode in the menu options.
> Anthony
