G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.work_remotely (More info?)
I recently had to re-install my OS (XP Pro SP1), and now for some
reason I cannot Remote Connect with Remote Desktop. When I attempt to
connect I get to the login screen, enter name and password and get a
dialog box saying
"The System could not log you on. The server authenticating you
reported an error (0xC00000BB)
I have googled that event code and the only thing that I could find at
all was referencing a Smart Card and SP2 (of which I am using neither)
In the Event Log, there is an error for the TermDD process:
"The RDP protocol component X.224 detected an error in the protocol
stream and has disconnected the client."
I have been trying to find information and help resolving this issue
for over a week now with no luck. Any help would be greatly
appreciated.
Thank you.
Posted using the http://www.windowsforumz.com interface, at author's request
Articles individually checked for conformance to usenet standards
Topic URL: http://www.windowsforumz.com/Work-Remotely-Remote-Connect-XP-PRO-SP1-Help-ftopict546169.html
Visit Topic URL to contact author (reg. req'd). Report abuse: http://www.windowsforumz.com/eform.php?p=1725747
dialog box saying
appreciated.
Thank you.
