Archived from groups: microsoft.public.windowsxp.work_remotely (More info?)
Hi
I've set up 2 computers at my work to be remote desktop hosts. I've got a
Linksys router at work that supposedly allows multiple VPN connections (not
pass through, but the VPN tunnel terminates at the router allowing access to
the network at work).
The VPN part works fine.
The Remote Desktop runs fine.
UNTIL...
The second user establishes a VPN connection and then tries to access their
RD computer (a different one from the 1st user). At that point, the 1st
user's system freezes, then is logged off. No error message or warning like
you get if a second user tries to access the same RD host. Just F-R-E-E-Z-E
and then a couple minutes later, they're logged off the remote network.
