Archived from groups: rec.video.desktop (More info?)
for a friend - wants to convert his VHS to DVD. Not even sure which
software to recommend. I was thinking Adobe Premiere Elements or
Pinnacle Studio. His computer also support USB 2.0. I think a PCI
capture card will get the job done reasonable.
"Richard Crowley" <rcrowley@xpr7t.net> wrote in message
news:11gnpgjh273r00c@corp.supernews.com...
> "Mark Burns" wrote ...
>> discussing on another link:
> http://groups.google.com/group/alt [...] d7fd150406 >
> Why go to all that trouble capturing/compressing to MPEG2
> on a computer. And especially trying to edit MPEG, yuck!
Sorry, Dick; but HD has already put a crimp in that old
attitude. And "Smart" Rendering/Encoding puts it further
in the past. You'll be editing MPEG soon, or be left
totally behind.
> Just get a standalone DVD recorder and copy straight
> across. The kind with a built-in hard drive will allow
> you to do basic assemble editing.
You do realize that functionally a DVD recorder is just
a box with a hardware capture card, and a DVD-/+RW
or DVD-RAM drive, operating on some limited firmware.
Some have added a harddrive to the mix, but are still
very limited compared to what the same components
can do in a PC.
To the OP; because the DVD recorder is an easy to
operate capture device, as easy as a VCR, it may be
that you could find it beneficial to use one to make
DVD+/-RW disks and bring those to your PC to use
the PC's more versatile editing and authoring ability.
The PC capture allows a better control over the
parameters of the MPEG being created, but the DVD
recorder may do well enough for most uses.
"Ken Maltby" <kmaltby@sbcglobal.net> wrote in message
news:ErCdnf1SPOvhX5HeRVn-3A@giganews.com...
> I can agree with most of that, for some and as a reflection of the
> current situation. But, at the level of editing that most people
interested
> in "rec.video.desktop" would be doing, MPEG is no longer the uneditable
> format it once was. The idea of it doesn't deserve a "yuck" anymore.
> As the industry gets into it, HDV is bound to improve and will force
> additional improvements in compression/encoding technology.
I kinda see it the other way around. If manufacturers develop MPEG data
systems for video then developers have little choice but to implement them
somehow. it ain't pretty.
> It may be more accurate to say MPEG is in transition. There is
> certainly big differences between MPEG-1, MPEG-2, MPEG-4.
> and the current HD versions. (DivX HD and WMV HD).
That's true.
> As this progress unfolds there will be further adaptations by those
> providing editing tools. We already see plug-ins being added to a
> number of the traditional editing packages. It is only very recently
> that those working on such tools have themselves started to put the
> MPEG Editing "yuck" dogma aside work on the issue.
I still feel it is a nasty format to work and edit in. I feel they should
have gone the other way with it and stuck with frame based compression and
higher data rates. I would gladly buy new gear to accomodate that but after
doing some HDV work , dealing with Cineform and the like.. I'll wait.
You're probably correct about the market though. It will certainly be
swamped with MPEG editing for the forseeable future. It is a little hard to
see into that future cause of the blockiness of the compression..
On Wed, 24 Aug 2005 13:54:47 -0500, "Ken Maltby" <kmaltby@sbcglobal.net>
Ken, maybe you should check the specs of those packages. Most work by
transcoding the MPEG material to an intermediate-codec. Thereby skipping
the problem the delay trying to find an image in a GOP, and to prevent
multiple re-compressing of frames, when cutting in GOPs.
"Martin Heffels" <biz@thisproductworks.com.> wrote in message
news:b9hpg1d697m1g8qgvr8bi39t0q97oamv1n@4ax.com...
> cheers
> -martin-
> "Beer is life!"
Yes & No, most traditional "non-destructive" editors do that, and
most of the newer "Smart Encoding" editors do that for the preview
and to apply effects. When it comes time to write the final output
however, only the effected GOP(s) are transcoded ( using data
derived during the rendering of those GOP) the rest are simply
copied.
Of course if you were to apply an image altering effect to the
whole video, then all the GOP would need to be altered and the
whole thing would be transcoded. Fortunately, most edits are
applied to only a very small percentage of the GOP in a clip.
On Wed, 24 Aug 2005 15:02:44 -0500, "Ken Maltby" <kmaltby@sbcglobal.net>
wrote:
>Fortunately, most edits are applied to only a very small percentage of the GOP in a clip.
The main thing is to chose a native MPEG-editor with the best
quality-codecs, or else the mage will be ripped even further. Is there a
test available somewhere, testing the quality of the encoders of these
native-editors?
Any WinTV or ATI all-in-wonder card will do. Used ones on ebay for <$50
will do fine. Add VirtualDub for the video capture, and you'll be doing
D1 resolution 720x480 30fps/29.97fps captures to the HD at any time w/o
any problems.
You can easily take any video stream and drop it into the PC this way,
dirt-cheap, and reliably all the time.
Use Huffyuv or PicVideo MJPEG video codec if you want higher capture
quality; otherwise, any ol' DV AVI video codec will do fine.
"David Chien" <chiendh@uci.edu> wrote in message
newsel6gu$g61$2@news.service.uci.edu...
> any problems.
> www.videohelp.com for more help on codecs, etc. in the forums.
> www.virtualdub.org for more help on VDub.
> TV-Top DVD recorder, like that 1 Tetrabyte (1000 GB) DVD/HD model just out
> in Japan would easily take care of any problems archiving most videos.
I prefer the hauppauge wintv-pvr 150, because of the 3comb filter...
