Archived from groups: rec.video.desktop (More info?)
I have captured with zero dropped frames from my miniDV camera many
times. I also captured one VHS tape via the pass-through feature of
the camera with only 4 dropped frames. The next VHS tape I tried was
impossible to capture because of hundreds of dropped frames. So, I did
a test and went back to the first VHS tape and found that I was unable
to capture it, as I had previously, without too many dropped frames.
These problems got me curious so I disconnected the VCR, changed
firewire cables, restarted the computer, and hooked up my camera
only. Now, I can't even capture from my camera without hundreds of
dropped frames, using the same set-up that had worked many times
previously.
On Thu, 25 Aug 2005 14:55:39 -0400, Registered User <not@today.com> wrote:
>It's a fairly new drive, used just for editing. I will check it,
>though. No new software has been installed.
New drives also need a couple of times to run a full speed for writing. You
can find patches at the manufcturers website to bypass this. It's a
diagnostic to check the quality of the drive.
> previously.
> Anyone know what might cause this?
> TIA
Firewire connections do conk out sometimes. You've tried two devices
with the same result that previously worked.
Well, I can see the video fine, without skips, in the preview window
of VideoStudio. It's only when I try to capture that it's a problem.
Could this still be a firewire problem?
>Try scenalyzer
>http://www.scenalyzer.com
>The eval version is fully functional and will help you test if perhaps
>you current capture app is just messing with your head.
Thanks, I've heard it was good. I'll try it next. The HD did need a
defrag so I'm waiting on that. Before defragging started, I tried
WinDV. User reports said it was great, but it also dropped frames.
