Archived from groups: rec.video.desktop (More info?)
Hi Everyone,
I recently bought a little USB TV Receiver with a view to using it record my
favourite TV shows and archiving them onto DVD's. I'm hoping to be able to
re-encode the captures into avi (DivX) format, so that I can then watch them
on my Standalone DVD that supports that format. The intention was to get as
much as possible onto the DVD's, hence my preference of DivX/XviD.
Now, the DigitalTV decoder only appears to have very limited options as far
capturing goes and I can only save captured video as Mpeg2. The quality of
these captures is excellent and I'm very happy with them, however, when it
comes to converting to avi I seem to be having some problems.
The mpeg2's are quite large files, just under 2Gb for an hour of video and
when I convert them to DivX format, using DrDivX, the file size is reduced
to around 600mb which is still quite a lot for an hour's video but I like to
keep the image quality as high as possible. Here's where the problem comes
in; the conversion looks and sounds great, but at about 5/6th's of the way
through there is a dramatic loss of audio sync. It goes out by at least 3
seconds, which is unacceptable.
I've tried changing various settings under the DrDivX options and
re-encoding but it makes no difference. I have also tried encoding direct
to DVD using Nero and the same thing happens. I've also tried converting to
XviD with AutoGordianKnot and it fails to convert.
I wonder, is this a common problem encountered when trying to convert from
an mpeg2 file? Can anybody recommend any other software that I could try?
Vince:
Try VideoRedo immediately on the captured file. It will correct out of
sync video and audio frames. Ken Maltby, I, and others have a
discussion elsewhere on this:
"Mark Burns" <marcus520520@yahoo.com> wrote in message
news:1125372066.203807.249190@g14g2000cwa.googlegroups.com...
> Vince:
> http://groups.google.com/group/alt [...] d0093fc974 >
> VR is $50 with a 30-day trial. Best investment that I made a while
> back.
> Cheers...
> Mark
Many thanks for the advice, Mark. I've just finished re-encoding the file
to AVI and it worked perfectly and even knocked another 100mb off the
finished file :-)
news:1125448328.821575.117480@g14g2000cwa.googlegroups.com...
> Vince:
> Glad to hear it. I assume that you used VideoRedo on it?
> Cheers...
> Mark
I did indeed, Mark.
It's an excellent little program and I'll definitely be buying a full key
for it when the trial is up. I'm just getting to grips with removing some
ad's in a programme that I recorded tonight and it's looking like it's very
user friendly. I can see this getting a lot of use :-)
