DAC-100 problem?
G
Guest
Guest
Archived from groups: rec.video.desktop (More info?)
Hi,
I have a DAC-100 and have just started to use it. No matter what, I
cannot get anything via the S (S-VHS) socket.
Using the supplied RCA cables, I can get sound and vision but thought
the sound starts to play back ok, a few seconds later there is like a
flutter on audio.
Is the unit likely to be knackered?
TIA
Jimmy
322
I have the DAC-100 and have always found the input S-video connector is
intermittent while the input phono connector works fine. I can get the
S-video connector to work by wiggling the cable connector a few times
while pushing it firmly in. Don't forget to use the source button to
lite the AV lamp.
No-one wrote:
> Hi,
> flutter on audio.
> TIA
G
Guest
Guest
>lite the AV lamp.
>No-one wrote:
>> Hi,
>> flutter on audio.
>> TIA
Thanks for that. The S-Video socket may be temeperamental but the
sound is something different, possibly PC based. I have found that
watching (Not recording) through Avid Free DV or Power Director is
fine, it is only when I record that the problem with the sound starts.
I think I will swop the sound card to see if it may have something to
do with it and also try the unit with a different PC.
Regards.
