Archived from groups: rec.video.desktop (More info?)
Hiya
I have a unique problem with home burnt DVD's - I can't copy them !
I store all my DVD images on my HDD incase I need to burn another copy
- but I lost a project after a HDD crash and I needed another copy for
a friend, so I thought I would just copy the files to my HDD (there's
obviously no copyright protection).
Explorer gave me a "data error (cyclic redundancy check)" at 75%
copied (the final VOB file).
I tried with DVD Decrypter (as recommended by a mate) but that stops
at 75% an I/O Error ; either -
"Interpretation : No seek completed" or
"L-EC Uncorrectable error"
Out of interest I took some other home movies off the shelf and they
all stop at 75% with either of the above errors.....
But the DVD's play perfectly on at least a dozen stand-alone DVD
players (including a PS2) and on every PC that I have tried them on ?
A couple of friends have tried to copy them as well and they always
crash out at 75% !!!
On one hand this is great as I know that when I produce DVD's for
people they cannot make copies of the wedding for Aunt Doris - but on
the other hand it's very very annoying as I don't understand what's
wrong ?!?
I have tried this with several different brands of media, on DVD+R &
DVD-R and it's always the same !
If someone thinks that they could help - I'll submit my software &
hardware profiles for contemplation....
Yup
Tried just copying the files as data - but still the cyclic redundancy
error.....
If I could work out what's happening I wonder if I should patent the
idea and sell it to the industry ;-)
j'arrow
On Fri, 09 Sep 2005 12:44:42 GMT, Gary Eickmeier
>You're just copying the Video TS folder off the disc, right? I see no
>reason why you couldn't - it's just a set of files.
>Gary Eickmeier
> Hiya
> j'arrow
Are you sure the videos don't start breaking up and skip when you get to
the 75% mark when playing on stand alone DVD player? DVD players have
some built-in error correcting. Since Nero won't make a copy, it sounds
to me like you have a corrupt file.
It's possible that there's an error on the disk that the DVD players
are circumnavigating... and that error would have to be on every burn
- if that's the case then the DVD burner could be the problem...
I don't know if Nero will make a copy as I've been unable to copy the
files to the PC... I wonder if I should try a Disk-Disk copy with Nero
j'arrow
>> Hiya
>> j'arrow
>George
> j'arrow
>>> Hiya
>>> j'arrow
>>George
Is the 75% where the error occurs a percentage of the actual file size
or the same location on the disk ?
If you have a consistant error occuring you either have a problem with
the writer or a bad batch of disk blanks.
Are you using read after write verification ?
My DVD player is a cheap piece of stuff but it seems to play anything
no matter how badly scratched up. I have to assume from its performance
that it just ignores errors and plays whatever it can find.
On Fri, 09 Sep 2005 10:31:27 GMT, j'arrow@home.net wrote:
>Hiya
>wrong ?!?
>thanks in advance
> j'arrow
TMPGEnc 3.0 XPress or TMPGEnc DVD Author 1.6 DVD import wizard
might work but Iso Buster never fails. XPSP2 sometimes chokes on UDF
1.02 files I've found.
Thanks Matey -
I'll download that and give it a go ! [WinXP-PRO SP2 tho' ?!?)
j'arrow
>>Hiya
>>wrong ?!?
>>thanks in advance
>> j'arrow
>Iso Buster will get your DVD files to your HD
>http://www.isobuster.com/
Ummm - not sure I'm doing this right !!!
in Isobuster - Extract DVD-R <image>
User Data (.tao .iso)
at 68% hit the error :
"Unreadable Sector"
Clicked "Replace with all zeros"
3 hours later and it's still 68% and Not Responding...
What am I doing wrong please ??
TIA
j'arrow
On Sat, 10 Sep 2005 11:29:38 GMT, j'arrow@home.net wrote:
>Thanks Matey -
> j'arrow
>>>Hiya
>>>wrong ?!?
>>>thanks in advance
>>> j'arrow
This whole thing may be a *mechanical* problem with
the drive itself (laser positioning mechanism sticking at the
same place every time).
Try a different drive.
<j'arrow@home.net> wrote in message
news:hc26i1198vpsqjvm8k4bhlvivbi1q44465@4ax.com...
> "Unreadable Sector"
> TIA
> j'arrow
> >Thanks Matey -
> > j'arrow
> >>>Hiya
> >>>wrong ?!?
> >>>thanks in advance
> >>> j'arrow
CRC Redundancy check means that the disc is physically failing. Most
likely the media was of bad quality to begin with. (There's mountains of
bad quality DVDR media lining the store shelves in North America and
elsewhere. Typically it's made by Infosmart and it fails faster than you
can say "Made in Hong Kong." Identifying the good stuff is not always
trivial as they immitate the media ID codes from better manufacturers.)
Unfortunately there does not appear to be a definite solution to your
problem. All I can suggest is to try reading it on different DVD burner
drives, as not all are equal in terms of error correction. The LG-4163B
and Plextor PX-716 are notably better than most in this area than most.
NEC drives are poor, but have many other advantages.
And FYI, the industry has used "fake" CRC failures as copy protection for
quite a few years now. Back in the days of 5.25" floppy discs, they used
to store special "original copy" signatures in sectors on the disk that
were disguised as "bad sectors" so that most 1:1 copy utilities would
skip them when someone tried to pirate or back up the program.
j'arrow@home.net wrote in news:rb23i15v5c9v8ktml9bbpamp5m315vik8r@
4ax.com:
> Yup
> error.....
Thanks to everyone !
JimK - IsoBuster took about 16 hours - but got there in the end, had
an issue with the IFO files not matching the VOB when I went to burn -
but processed the files through DVD2ONE (movie mode) and reconstructed
the DVD - burnt & played perfect !
Thanks again for all your help
j'arrow
On Sun, 11 Sep 2005 00:49:41 -0500, Jucius Maximus
>4ax.com:
>> Yup
>> error.....
> j'arrow
In the future, you might consider buying a DVD writer that is able to
do PI/PO error scanning of media using a tool like Kprobe, DVD Info
Pro, or Nero CD-DVD Speed, such as a BenQ or LiteOn. If you see a
certain type of media or certain discs burned at a certain speed get
large error counts (especially near the end of the disc) then you can
identify and fix those problems before it's too late by reburning on
different media or at a different speed.
If you take a snapshot of the disc right after burning and then later
in time, you should be able to see if it's degrading and how fast. It
helps tell you if the drive or media is at fault.
