Tom's Hardware > Forum > Graphic & Displays > TV/Video Cards > Scene detection problem...mystery?
Forum Graphic & Displays : TV/Video Cards - Scene detection problem...mystery?
Archived from groups: rec.video.desktop (More info?)
I was using a JVC DV camcorder with Sony Vegas 5 and Pinnacle Studio
9... capture via firewire. No problem with scene detection with
either program. Each discrete scene was being detected, and so I would
not have to manually split up a video. Recently I switched to a
Samsung DV camcorder. Now when I capture my videos shot with the new
Samsung, I end up with only one long video, it doesn't separate into
scenes. Same thing with either Studio 9 or Vegas 5. Its the camcorder
that is the problem. I took an old tape that was shot with the JVC
camcorder and played it in the Samsung, capturing a video with several
scenes. With this old tape, scene detection worked fine!
Whatever it is, it is something to do with the record mode on the new
Samsung, that is not allowing scene detection. Problem with time
code, maybe? But even if time code was not being encoded, wouldn't
these programs be able to detect scenes from the suddenly changed
image?
Sponsored Links
"Geronimo" <someone@somewhere.net> wrote in message
news:2819i1tk9bq6hsjaku5c7mmsol6b34ildp@4ax.com...
> image?
Scene detection is done either optically, based on analysis of the image in
each frame, or by breaks in the time and date information. Your new
camcorder may not record time and date or, alternatively, you'll need to
turn on that feature.
Reply to Anonymous
Yea, that is what I am thinking.... time code might be turned off..
But it still doesn't explain why neither Studio 9 nor Vegas can't
detect scenes optically.They should still be able to do it that way
even if it is, right?
I scrolled through the on-screen camera mode menu and did not see any
option to turn off SMPTE. It is an Samsung SCD27, surely it encodes
SMPTE? Don't all of the mini-DV camcorders have SMPTE time encoding?
thanks, Jeronimo
On Sun, 11 Sep 2005 19:47:04 GMT, "PTravel"
>> image?
Reply to geronimo
I don't know about Studio 9 but I can tell you that Vegas does NOT do
optical scene detection.
You need an app like Scenalyzer (demo at
http://www.scenalyzer.com/main.html ) for that.
Also, you seem to be confused in that, if you see the on-screen counter
incrementing, you think that time code is being recorded on tape. It's not
unless you have the camera's internal clock activated. Since you said this
is a new camera, my guess is that you've failed to do this. Make sure it's
set correctly and I'm certain your problems will be over.
BTW, miniDV timecode is not true SMPTE timecode like the higher-end (pro)
camcorders use.
Mike
> thanks, Jeronimo
>>> would not have to manually split up a video. Recently I switched to
>>> a Samsung DV camcorder. Now when I capture my videos shot with the
>>> new Samsung, I end up with only one long video, it doesn't separate
>>> into scenes. Same thing with either Studio 9 or Vegas 5. Its the
>>> camcorder that is the problem. I took an old tape that was shot
>>> with the JVC camcorder and played it in the Samsung, capturing a
>>> video with several scenes. With this old tape, scene detection
>>> worked fine!
>>> new Samsung, that is not allowing scene detection. Problem with
>>> time code, maybe? But even if time code was not being encoded,
>>> wouldn't these programs be able to detect scenes from the suddenly
>>> changed image?
>> image in each frame, or by breaks in the time and date information.
>> Your new camcorder may not record time and date or, alternatively,
>> you'll need to turn on that feature.
Reply to Anonymous
> camcorders use.
> Mike
Adobe Premiere Pro does optical scene detection, as does Scenealyzer as
you've noted. The shareware (free) version of Scenealyzer can do it,
too.
Good point about the on-screen counter. Once, I had re-set my VX2000
and didn't bother setting the clock/calendar. I shot 3 or 4 tapes
before I realized that I wasn't getting time/date code recorded.
Worse, 2 of the tapes were of fireworks at New Years in Copenhagen. I
used Scenelyzer for optical detection, but it was thrown off every time
some fireworks went off (which was every couple of seconds).
> > thanks, Jeronimo
> >>> worked fine!
> >>> changed image?
Reply to Anonymous
> thanks, Jeronimo
It's not SMPTE -- it's just date and time and should be recorded
automatically as it's part of the miniDV spec. Hey, I just thought of
something -- in my reply to Mike Kujiba's post, I related an instance
in which I reset my camera, but didn't set the date and time. I
assumed that the camera would just record date and time based on
whatever the initial default is, e.g. 12:00 am 12/1/80 or something.
In fact, it didn't record date and time at all.
So . . . is your date and time set?
As for optical detection, Mike Kujiba says that Vegas doesn't do it,
and I don't use Studio 9, so I couldn't say. I did used to use Studio
7 and I seem to recall that it could. Anyway, Premiere Pro definitely
does, but the best solution is to download a free copy of Scenealyzer,
which will take your full-tape captures and do very creditable optical
detection.
> >> image?
Reply to Anonymous
You guys are dead-on it I'll bet. It is a used camcorder I bought from
a guy in Canada, so I thought it was still set, but just not showing
on-screen. But it was not set ,it was showing Jan 1 2003. I assumed
that even if time/date was not set, it would just record the default
time code to tape....but I guess not. Haven't tried it again since
setting time, but I am sure that should do the trick. Thanks again, J.
>> thanks, Jeronimo
>detection.
>> >> image?
Reply to geronimo
The "Jan 1 2003" is a dead giveaway that this is the problem.
Glad to have been of help :-)
Mike
>>> any option to turn off SMPTE. It is an Samsung SCD27, surely it
>>> encodes SMPTE? Don't all of the mini-DV camcorders have SMPTE time
>>> encoding? thanks, Jeronimo
>> of something -- in my reply to Mike Kujiba's post, I related an
>> instance in which I reset my camera, but didn't set the date and
>> time. I assumed that the camera would just record date and time
>> based on whatever the initial default is, e.g. 12:00 am 12/1/80 or
>> something. In fact, it didn't record date and time at all.
>> Studio 7 and I seem to recall that it could. Anyway, Premiere Pro
>> definitely does, but the best solution is to download a free copy of
>> Scenealyzer, which will take your full-tape captures and do very
>> creditable optical detection.
Reply to Anonymous
There are 678 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
