VPN Ipconfig problem
Forum Windows XP : Windows XP General Discussion - VPN Ipconfig problem
Archived from groups: microsoft.public.windowsxp.work_remotely (More info?)
I have the following problem.
I've setup a VPN server on a winxp pro. Everything works fine, I can connect
to it and transfer files. The problem es that connected or not when I access
de CMD and type ipconfig I don't recieve the usual device information. I
can't see the adapter. When I try to release or renew de IP it says something
like "no device found". I repeat, this happens even if i'm not connected to
the VPN. It seems like the creation of the VPN takes control on the adapter.
Any sugestions? Thanks in advance.
Sponsored Links
You state "ipconfig" you dont see the adapter...are you using the /all
switch, as in: ipconfig SPACE /all - this will show all adapters and you may
even need to open the cmd window longer height wise to see it too. See below,
the PPP adapter configurations.
Example:
C:\Documents and Settings\Owner>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : xx
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : vpn.ms.com
ms.com
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . : host.inet.net.
Description . . . . . . . . . . . : Intel(R) PRO/100 VE Network
Physical Address. . . . . . . . . : 00-11-22-33-44-55
Dhcp Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IP Address. . . . . . . . . . . . : 10.x.x.x
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 10.x.x.x
DHCP Server . . . . . . . . . . . : 10.x.x.x
DNS Servers . . . . . . . . . . . : 10.x.x.x
Lease Obtained. . . . . . . . . . : Friday, July 29, 2005 4:47:5
Lease Expires . . . . . . . . . . : Tuesday, August 02, 2005 7:4
PPP adapter VPN connector VPN:
Connection-specific DNS Suffix . : www.xyz.com
Description . . . . . . . . . . . : WAN (PPP/SLIP) Interface
Physical Address. . . . . . . . . : 00-11-22-33-44-66
Dhcp Enabled. . . . . . . . . . . : No
Subnet Mask . . . . . . . . . . . : 255.255.255.255
10.x.x.x
Primary WINS Server . . . . . . . : 10.x.x.x
Reply to Anonymous
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > VPN Ipconfig problem
There are 1303 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
