Tom's Hardware > Forum > Graphic & Displays > TV/Video Cards > Panasonic PV-GS1 ~ Shooting Problems
Forum Graphic & Displays : TV/Video Cards - Panasonic PV-GS1 ~ Shooting Problems
Archived from groups: rec.video.desktop (More info?)
Hi Guys,
I'm using a Panasonic PV-GS150 Camcorder.
After looking at my 'footage' :
1) Why the images on my LCD look, in term of light, OK but looking at
the same footage on a TV screen (connected to my Camera) they look much
much darker ?
(I was freeking out when I saw it)
2) There seem to be an 'adjustement period' moving betwen different
areas with different lightning. For example, if I'm shooting outdoor
in an area with a lot of light and then going into a more shady/darker
area, then looking at my footage afterwords, there are a few secounds
where the camera 'adjust to the new lights' is there anything I can
do to make the transition seamless ?
Thank you so much for your time. Any help or refering to other
resources will be very helpful.
Be well,
~ Grace
Sponsored Links
gs wrote:
> Hi Guys,
> much darker ?
> Be well,
> ~ Grace
You may want to get a grayscale and color card to ensure your
television is correctly adjusted.
Your camera should adjust to the light conditions but it may read the
light level at the center of the frame. You may nned to slow down your
camera movement to allow it enough adjustment time.
Reply to Anonymous
"gs" <shulner@media.mit.edu> wrote in message
news:1126988536.668255.134750@f14g2000cwb.googlegroups.com...
> Hi Guys,
> much darker ?
This one got me too. If this is the same as mine, there should be a green
light on the LCD screen (right next to the latch that opens the LCD door).
This is actually a button that brightens the LCD screen (for daylight
viewing). Push that button until the green light goes off and the screen
should darken considerably.
Tom P.
(This also wastes battery power so that will go up as well.)
Reply to Anonymous
There are 1156 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
