Tom's Hardware > Forum > Graphic & Displays > TV/Video Cards > Can 2 Firewire cards in same computer cause a problem?
Archived from groups: rec.video.desktop (More info?)
I installed a dedicated 3-port Firewire card in my computer to see if
capturing through it makes a difference with a problem I'm having. However,
I'm now having a problem with the computer locking up.
I was using the firewire port on an Audigy soundcard, which is still
installed. Could/should the presence of 2 cards with Firewire ports cause a
problem? Whatever problems I was having, it never locked up before.
The brand of the dedicated Firewire card is Stratictech, bought as Wal Mart
if it's of any significance.
Thanks for all shared wisdom.
Sponsored Links
What computer slot did you install it in? The slots (#1 or 2) that are
closer to the processor and video card should be where that card is
installed. Those generally have priority motherboard bandwith over
cards lower in the layout. So the lockup could be when you are bringing
in alot of data and computer cant' handle the bandwith.
As for the audigy, you should be ok w/ 2 cards installed. A brand name
card is always better than a wal-mart brand, but it should work.If you
have a PCI-X 100mhz or 133mhz slot (check your manual), install the
firewire card in that one. If it's a standard 33/66mhz then install in
slot 1 or 2.
Another problem could lie in the hard drive speed and data transfer
rate. If you are capturing to your system drive, then that could be the
cause of lockups because drive can't handle the bandwith needed for
video capture. If you have a dedicated video capture drive, that could
eliminate your lock-ups if that's what's causing it to do so.
Hope this helps!
- Henry T Kirk
4VideoEquipment.com
Henry@4VideoEquipment.com
Http://www.4VideoEquipment.com
Reply to Anonymous
- 0 +
Could very well be true, but I've had 2 Firewire cards (from 2 different
vendors with 2 different chipsets) installed in slots 1 and 4 for over a
year with no lockups or other issues.
Smarty
"4VideoEquipment" <henry@henrytkirk.com> wrote in message
news:1127422901.526665.115460@g49g2000cwa.googlegroups.com...
> slot 1 or 2.
> Hope this helps!
> - Henry T Kirk
> 4VideoEquipment.com
Reply to Smarty
There are 1137 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vishnuvamp won the Freshman badge
  • 01:00 whiz won the Freshman badge
  • 01:00 jconline won the Uniformed badge
  • 01:00 qiaoda won the Uniformed badge
  • 01:00 sykohedd won the Uniformed badge
  • 01:00 jundja won the Uniformed badge
  • 01:00 cnsftci won the Uniformed badge
  • 01:00 VistaVendetta won the Uniformed badge
  • 01:00 batuchka won the Uniformed badge
  • 01:00 Nick_C won the Uniformed badge
