Tom's Hardware > Forum > Old Man/Woman's Club > Other > Optical digital sound cable ..
Forum Old Man/Woman's Club : Other - Optical digital sound cable ..
Well, I don't know what is the difference in those optical wire. I plan to run one from my computer sound card to my home theater receiver, and while some are cheap, other are pretty expensives.
What is the difference between the cheap one and the expensive ones?
I know that there must be quality, but how does that matter?
Sponsored Links
Just buy cheep speaker wire. Don't fall for all that gold connector B. S..
All that expensive crap isn't necessary to wire your house for sound.
Reply to russell
- 0 +
DAMN IT!!! I get paid to do this normally because i do this at work all day but here goes....
Buy a monster 400 optical one. They are roughtly 39.99 but they have a lifetime warranty so if the cable has any problems they will take care of it which is nice.
Bascially the difference is when the light is going through the wire you want the wire to be as clean and clear as possible. higher quality cables are more clear, so the light doesn't bend within the cable. honeslty its something i doubt you would notice with a cheap cable, but i still say go with the cheapest monster or cheapest god brand you can find.
Reply to pickxx
- 0 +
No, I mean optical fiber wire for home theater. I need one to connect my sound card output to my receiver for dolby digital 5.1 sound. I don't have any coaxial connector left on my receiver.
Reply to pat
- 0 +
Quote :
Optical wires dont have gold connections my friend.....lol
Reply to pickxx
- 0 +
So, do you think the cheapest one would do the same for a while if my computer is at 10 feet from my receiver? This will be the fartest the computer will be from the receiver.
Reply to pat
- 0 +
Thats the bonus about optical....you can have it like 700ft from your reciever...the length almost desn't matter (over like a mile is starts to matter....i assume you will be closer then a mile...lol)
Also you dont have to worry about bending and createting sharp angles like you do with digital coax....you can run it in a tight spiral if you want....same quality.
Fibre Optical is my personal choice for all home seups over digital for those reasons above.
the 12ft fibre optical monster is like 49.99 at BestBuy i think.
i could look it up but i am lazy.
Reply to pickxx
- 0 +
Thanks. I don't have any Best Buy near , so I'll look at store near home.
Reply to pat
- 0 +
I work at BB so thats why i know this.....
BB owns a compeny and they refr to it as "The BestBuy of Canada" but i forget the name....
but check around for some decent 12ft fibre optical cables.
Reply to pickxx
- 0 +
got some at around 30$ online. will go to the store tomorrow
Reply to pat
- 0 +
what are you talking about light, optical?????
Are you saying that he has a fiber optics out on his sound card????????????
COME ON
Reply to russell
- 0 +
yes.. I have. look at this card
The black thing is actually a plug that..plug the hole for the fiber optic cable.
By the way, it is not that card that I have, but one that has the same thing. It use TOSLINK cable to send digital signal by optic fiber to the dolby receiver.
Reply to pat
- 0 +
Quote :
I'll be darn!
But isn't that overkill? I mean, do you really think that you could hear the difference between fiber optics and speaker wire?
I mean you could use a couple of phono Jack plugs and cheap wire . Would there be a noticeable difference?
Reply to russell
- 0 +
Well, the use for that is not for music, but rather movies. This cable carry the signal to create the 5.1 dolby effect as seen in the cinema. With surround sound. You only have one cable that drives like 6 speakers, 1 left-rear, 1 right-rear, 1 front, 1 front-right, 1 front-left and the bass box. My PC is connected to my TVset and hometheater reciever, so I can wach movies, be it DVDs or Divx in their full sound effect when their are encoded with AC3. just like in theater.
Reply to pat
- 0 +
Quote :
COME ON
Yeah he said in his first post about it that he had a Fibre out on his SC....which i know a lot of cards now have....its no different then a card having a digital coax out. Same digital high quality....each has up's and down's but they are available.
And YES!! RCA jacks can only carry stereo sound....the fibre and D coax can carry a digital 5.1 signal. So would you notice between 5.1 and 2.1? I think you would.
Also its not optical TO the speakers....just the receiver. then you are using standard speaker wire to the speakers.
Reply to pickxx
- 0 +
Goes to show how far behind I am. :oops:
Reply to russell
- 0 +
not really Fibre opical being in receivers and SC's is pretty new. Like 1-2yrs. and has only recently become affrodable.
Reply to pickxx
- 0 +
Quote :
But now you know. So, if you ever get a new sound card and a home theater receiver, you'll know that you can connect them digitally to enjoy the best sound quality for your movies
Reply to pat
- 0 +
The thought of optical didn't even enter my mind.
I was thinking about the pre made speaker wires with the gold plated plugs on them they sell to the gullible American consumer.
I used to use RG8 and RG58 ,coax all the time on my ham radio. I ran a thousand Watts on frequencies as high as 30 MHZ. We had VHS and UHF radios on much higher frequencies but we were not allowed to use that much power there. The higher the frequency the greater the risk for signal losses on Long runs of coax. Even at 220MHz gold plated connectors were not needed .
I was just trying to save him some money.
Reply to russell
- 0 +
exactly digital coax quality depends on short wires......fibre optic wires dont have that problem and you can have sharp angles too...so wraping around a corner doesn't hurt anythig
Reply to pickxx
Optical is used for tranfering digital sound between the source and the amplifier. It's major advantage over digital coaxial is that it can be run over longer distances.
Reply to Crashman
- 0 +
Thanks crash. I'm familiar with optics. IHA just didn't know they've entered our living rooms already . HA HA
Reply to russell
- 0 +
Already? I've been running an optical cable for two years on my surround sound system...It's not 1975 Russ... :P :P :P :P :P :P
Reply to TeeTewl
d00d, I had an Aureal Vortex2 card from lthe turn of the century with digital optical out.
Reply to Crashman
- 0 +
:oops: Crawls back into cave.
Reply to russell
Quote :
LOL yeah the only way to get music onto my Minidisc player is via optical SPDIF.
my old Mobo used to have optical via an audio expansion bracket, it had 3 extra pin jacks a digital co-ax and an optical port.
my new mobo's (two of them that replaced my broken old one) don't have any optical. its a massive bummer.
AFAIK optical SPDIF was more common than coax in the early days of SPDIF. all the devices i ever saw with it were optical. i bought my MD about 5 years ago or more.
as for cables (to the original poster) darned if i would know, i have never had any issues and mine is the one that came with either the MD or the Mobo.
Alltaken
Reply to alltaken
There are 1330 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
