For some users, computer designs can't be small and quiet enough. Mini-box.com has begun offering what it claims to be the world's smallest ATX compliant power supply that uses a single 12 volt power source and puts out 120 watts. Read more
Thermaltake now offers a high performance power supply for users that just can't get enough power. The new model belonging to the Toughpower line provides up to 2 Kilowatts of power. Live demonstrations are given at the company's CeBIT stand Read more
OCZ Technology Group has introduced a new modular power supply with a sustained output of 600 watts. The PSU will hopefully lessen cable clutter because only the necessary power cables need to be attached. The titanium mirrored case comes with two PCI-Express cables and a 4/8 pin CPU auxiliary fan connector. Read more
Thermaltake Technology announced the launched of its new line of Purepower RX series ultra-low noise power supplies incorporating the ultra-silent 140 mm fan found on Thermaltake's high-end Toughpower Series power supplies. Read more
Core i7--previously referred to as Nehalem--requires new motherboards, coolers and memory. Its performance is compelling and means AMD is falling behind even further, but Intel is putting in some speed bumps that will impact overclocking enthusiasts. Read more
Three dramatically different builds face off in a show of performance, defining the real value of each. Our mainstream system is designed to meet the needs of most users. Who should spend more and who can live with less? Read more
For the second to last day of our System Builder Marathon series, we add a $500 gaming PC to the mix. It's not going to be as quick as our other two builds, but we think Paul was able to get some serious value from this thing. Read more
We're following up yesterday's $4,500 behemoth with a more affordable $1,500 mid-range build. Let's see what sort of performance (and overclocking headroom) you can get when you spend one third of the money. Read more
| Bottom | |
| Author |
Thread : Power supply, but no power???
More Information
Archived from groups: alt.comp.periphs.mainboard,comp.sys.ibm.pc.hardware.systems,comp.hardware (More info?) I believe a power surge toasted my power supply the other day, so I
Related Product
More Information
Archived from groups: alt.comp.periphs.mainboard,comp.sys.ibm.pc.hardware.systems,comp.hardware (More info?) On Thu, 07 Apr 2005 13:28:25 -0700, U. Cortez wrote:
More Information
Archived from groups: alt.comp.periphs.mainboard,comp.sys.ibm.pc.hardware.systems,comp.hardware (More info?) If the power supply is toasted, then you have an important
More Information
Archived from groups: alt.comp.periphs.mainboard,comp.sys.ibm.pc.hardware.systems,comp.hardware (More info?) Wes Newell <w.newell@TAKEOUTverizon.net> wrote in message news:<pan.2005.04.07.21.06.50.364178@TAKEOUTverizon.net>...
More Information
Archived from groups: alt.comp.periphs.mainboard,comp.sys.ibm.pc.hardware.systems,comp.hardware (More info?) > If the power supply is toasted, then you have an important
More Information
Archived from groups: alt.comp.periphs.mainboard,comp.sys.ibm.pc.hardware.systems,comp.hardware (More info?) The failed capacitors (and probably failed diodes) is
More Information
Archived from groups: alt.comp.periphs.mainboard,comp.sys.ibm.pc.hardware.systems,comp.hardware (More info?) On Fri, 08 Apr 2005 12:22:21 -0400, w_tom wrote:
More Information
Archived from groups: alt.comp.periphs.mainboard,comp.sys.ibm.pc.hardware.systems,comp.hardware (More info?) It sounds like the power surge also toasted your motherboard. This
More Information
Archived from groups: alt.comp.periphs.mainboard,comp.sys.ibm.pc.hardware.systems,comp.hardware (More info?) Well last night I tested the power supply (with it just plugged into
More Information
Archived from groups: alt.comp.periphs.mainboard,comp.sys.ibm.pc.hardware.systems,comp.hardware (More info?) On Fri, 08 Apr 2005 17:19:23 GMT, Wes Newell
More Information
Archived from groups: alt.comp.periphs.mainboard,comp.sys.ibm.pc.hardware.systems,comp.hardware (More info?) Overvoltage protection is not required for UL approval -
More Information
Archived from groups: alt.comp.periphs.mainboard,comp.sys.ibm.pc.hardware.systems,comp.hardware (More info?) Problem could even been created by a motherboard standoff
More Information
Archived from groups: alt.comp.periphs.mainboard,comp.sys.ibm.pc.hardware.systems,comp.hardware (More info?) On Sun, 10 Apr 2005 06:07:31 -0400, w_tom wrote:
More Information
