News
ULi concerned about supply-demand imbalance in PC chipset industry
Published on October 25, 2005
Motherboard makers and chipset specialists should be aware of the imbalance between positive PC demand and insufficient related component supply, which may result in inventory overhang in early 2006, said Alex Kuo, CEO and president of ULi Electronics. Read more
Tiny power supply cranks out 120 watts
Published on January 27, 2006
For some users, computer designs can't be small and quiet enough. Mini-box.com has begun offering what it claims to be the world's smallest ATX compliant power supply that uses a single 12 volt power source and puts out 120 watts. Read more
Mobo makers voice concerns about southbridge supply after ATI's Crossfire 3200 launch
Published on March 02, 2006
With ATI set to roll out its PCI Express (PCIe) CrossFire Xpress 3200 (RD580) chipset for high-end AMD solutions, motherboard makers are expressing concern about a potential southbridge supply shortage, as ATI partner Uli Electronics (ULi) was recently acquired by Nvidia. Read more
CeBIT 2008: Thermaltake Offers 2kW PSU
Published on March 09, 2008
Thermaltake now offers a high performance power supply for users that just can't get enough power. The new model belonging to the Toughpower line provides up to 2 Kilowatts of power. Live demonstrations are given at the company's CeBIT stand Read more
Latest Reviews & Articles
System Builder Marathon: Performance & Value
Published on October 31, 2008
Three dramatically different builds face off in a show of performance, defining the real value of each. Our mainstream system is designed to meet the needs of most users. Who should spend more and who can live with less? Read more
System Builder Marathon: $500 Gaming PC
Published on October 30, 2008
For the second to last day of our System Builder Marathon series, we add a $500 gaming PC to the mix. It's not going to be as quick as our other two builds, but we think Paul was able to get some serious value from this thing. Read more
Tom's SBM: The $1,500 Mainstream PC
Published on October 29, 2008
We're following up yesterday's $4,500 behemoth with a more affordable $1,500 mid-range build. Let's see what sort of performance (and overclocking headroom) you can get when you spend one third of the money. Read more
System Builder Marathon: The $4,500 Super PC
Published on October 28, 2008
This month's System Builder Marathon spreads the system prices out even further to $4,500, $1,500, and $500. Is today’s $4,500 system really worth three times as much as an upper-mainstream performance machine? Read more
  Tom's Hardware Forums » Motherboards & Memory » General Motherboard » Newbie POWER SUPPLY questions related to my MOBO w/FULL-TO..
Word :   Username :
Bottom
Author
 Thread : Newbie POWER SUPPLY questions related to my MOBO w/FULL-TO..
More Information
Archived from groups: alt.comp.periphs.mainboard.supermicro,alt.comp.periphs.mainboard,alt.comp.hardware.overclocking (More info?)
Hi all,
I'm researching new 500-Watt Quiet PSU's and need a refresher on the
specific criterion I should be looking for so the new PSU's like both
my motherboards and my (ATX) chassis. It's been four years since I
lined up parts to hand over to my technician and I apparently didn't
keep the notes I originally made when I/they first built these SCSI
Systems. That -- and the emergence of new SATA HDD's -- prompts my
request for help knowing what, specifically, my Supermicro Motherboards
are capable of handling with some of the newer PSU's and SATA HDD's now
hitting the market. I'm fairly certain of two statistics on my current
PSU's --
......they're 115 Volt
......they contain 12cm fans
Here's a fine example of specs I'm trying to navigate:
Nexus NX-5000 500-Watt Quiet PSU
______EPS12V
______ATX 2.01 FORM FACTOR
______SLI
______Dual PCI-Express
______(6) Molex 4-pin connectors
______(3) SATA connectors
______(2) Floppy conectors
The 4-pin Molex power plugs and the (2) floppy power cables are
familiar to me; but are EITHER of my Motherboards -and/or- my type of
Chassis
1.) "EPS" (eg. EPS 12V) Voltage specific?
2.) ATX _version number_ (eg. ATX 2.01~) specific?
3.) "SLI" . . . ? clueless
4.) "PCI-Express" . . . capable? (I don't even know what this is lol)
5.) SATA capable?
Currently I have only ATA and SCSI HDD's; but I'd like these power
supplies to be SATA-capable for future expansion purposes. Thank you
for any help. See my System Specs below for more detail.
Angel
SYSTEM SPECIFICATIONS
I have two Full-Tower (ATX) Systems built with two different SCSI
Supermicro Motherboards:
P6DGU <1000 MHz X 2>
P6DBS <850 MHz X 2>
Each System is a Dual-PIII (Windows 2000 Pro) standalone System.
Each System is housed in identical 6-Bay Full-Tower (ATX) Chassis.
Each Chassis currently has installed two 80mm Panaflo™ Quiet Fans.
The Chassis Mfg. indicates "room for three 8cm 2nd fans".
Related Product
More Information
'CURIOUS ANGEL' wrote:
_____
And the question is?
Phil Weldon
More Information
> _____
> Phil Weldon
I think the OP wants to know if a Nexus NX-5000 500-Watt Quiet PSU (or
similar) will fit into a standard ATX form-factor chassis and be compatible
with his SM P6DGX series motherboards. He also wants to know if the
P6DGX's will run a SATA HDD. My guess is that the answers are "yes,"
"yes," and "yes, if you add a SATA controller" but I am not sure about any
of those answers, I'm just trying to restate the question.
Bill Asher
More Information
Archived from groups: alt.comp.periphs.mainboard,alt.comp.hardware.overclocking,alt.comp.periphs.mainboard.supermicro (More info?)
On Mon, 29 Aug 2005 18:26:47 UTC in alt.comp.periphs.mainboard.supermicro,
> Chassis
No idea.
The manual for my P6DBE (and all the other models in that series) says it needs
an ATX 2.01 PSU.
No idea.
No. That's a newer form of PCI mainly intended for video cards. You'll need a
motherboard that's less than a year old to have this capability.
> 5.) SATA capable?
Not natively. If you have a spare PCI slot then you could add a SATA controller
to them.
A few of your local currency units will get you a Y shaped cable with a 4 pin
socket on one end and a pair of SATA power connectors on the other. Much cheaper
than a new PSU.
Trevor Hemsley, Brighton, UK.
Trevor-Hemsley at dsl dot pipex dot com
Profile: stranger
More Information
On 29 Aug 2005 11:26:47 -0700, "CURIOUS ANGEL" <byte.this@usa.net>
wrote:
>Hi all,
>PSU's --
>______EPS12V
>______SLI
>Chassis
>5.) SATA capable?
>Angel
>P6DBS <850 MHz X 2>
As Phil said " and the question is?"
Any power supply with adequate wattage and the correct connectors
should work.
If you are not replacing the mb's the SLI and PCI-e are not relevent.
PCI-e is the latest PCI type and allows you to use one of the PCI
slots for graphics (PCI-e x16) instead of AGP. SLI is a way to connect
two special PCI-e graphics cards together using two PCI-e x8 slots and
a hardware bridge that clips onto the two graphics cards. Both
technologies need to be built into the mb.
As far as SATA. If the power supply doesn't have these connectors (
most do) you can use an adapter. BUT as I understand it your SCSI
drives are faster than SATA II. Serial ATA ( I & II) has a ways to go
yet before it becomes "must have" technology. SATA is barely faster
than ATA.
Gollum
Google Ads
