News
GPS can help give early warning of tsunamis
Published on June 30, 2006
Using GPS (global positioning system) data to measure how points on land move following an undersea earthquake could help geologists decide if the tremor will cause an ocean-wide tsunami. Read more
MIT researchers developing a quarter-sized turbine engine
Published on September 20, 2006
MIT researchers have started putting entire gas-turbine engines on tiny silicon chips. With the help of some military funding, researchers have fashioned millimeter-sized compressors, combustion chambers and turbines and placed them on layers of silicon wafers. Read more
PhD Student Makes World's "Most Advanced" Walking Robot
Published on May 23, 2008
Delft (Netherlands) - A PhD student at the Delft University of Technology in the Netherlands has constructed what he says is the world's most advanced walking biped robot. Read more
Nvidia To Rename Cards To Help Alleviate Confusion
Published on May 08, 2008
Nvidia has revealed plans to simplify its product range so that people who aren’t as well versed in techtalk can understand what the company is trying to market. Read more
Latest Reviews & Articles
Efficiency: Core 2 Nukes Atom On The Desktop
Published on November 21, 2008
Atom is geared for low-cost, low-power netbooks and nettops, while the device is a poor choice for desktop PC applications. We show you why Core 2 is better, and give some guidance on how to pick the best power supply for your low-power application. Read more
Radeon HD 4870 X2: Four Cards Compared
Published on November 19, 2008
Not only do we have four super-fast Radeon HD 4870 X2s to test, but also a list of 31 other graphics configurations including CrossFire and SLI setups. If you're in the market for AMD's fastest card available, you'll want to see this. Read more
Synology's DS408 Reviewed: Fast NAS For Pros
Published on November 18, 2008
Does a NAS device with high data transfer rate and a Web interface that is easy to configure actually exist? Synology shows how it should be done. But the enclosure is not without its faults, either. Read more
The Hardware Behind Overdrive
Our worldwide overclocking championship has begun and we wanted to introduce you to the everyday components our teams will be tweaking to supersonic speeds in a bid for a shot at $5,000. Read more
  Tom's Hardware Forums » Motherboards & Memory » Abit » HSF Question - PLease Help
Word :   Username :
Bottom
Author
 Thread : HSF Question - PLease Help
Profile: stranger
More Information
Archived from groups: alt.comp.periphs.mainboard.abit (More info?)
I have an xp2700 on an abit nf7-s mobo and am unhappy with the stock
heatsink and fan. I had wanted to get the THermaltake SIlentboost, but
they don't make it anymore with the hydrowave bearing fan(the quiet
one).
So, I think i've narrowed down my choices to either the arctic cooling
copper silent 2L or the THermalright ALX-800 with either the Panaflo
L1A or M1A fan.
Is the TR worth the cost (it's twice as much as the arctic cooling?)
Also, if I do get the TR, which fan would be better? I plan on doing
some overclocking with it, but I also want it to be as quiet as
possible.
Thanks in advance!
Related Product
Profile: old hand
More Information
"BiPolar" <jlevin17@hotmail.com> wrote in message
news:86f23cd5.0404010936.1ba255a2@posting.google.com...
> one).
> L1A or M1A fan.
> possible.
> Thanks in advance!
You could also consider getting a Tt Volcano 12 & just not cranking it up.
At 2100rpm it is very quiet & always gives you the option to increase fan
speed if required.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.648 / Virus Database: 415 - Release Date: 31/03/2004
Google Ads
