Archived from groups: alt.comp.periphs.mainboard.abit (
More info?)
Robbie Wilson wrote:
> On Sun, 18 Apr 2004 18:19:39 -0400, "ICee" <icee@deadpeople.invalid>
>>> On Sat, 17 Apr 2004 17:05:56 -0400, "ICee" <icee@nospam.invalid>
>>>>> On Sat, 17 Apr 2004 14:29:31 -0400, "ICee" <icee@nospam.invalid>
>>>>>>> when i initially installed a cdwriter on this machine i could
>>>>>>> never enable dma on that drive. the drive would dissappear from
>>>>>>> explorer, would not be recognized by nero, etc. I used a dvdrom
>>>>>>> on secondary slave. the dvdrom drive would work fine with dma
>>>>>>> enabled and finally i gave up trying and used the cdwriter with
>>>>>>> PIO mode only. now that i have upgraded my cdwriter to a
>>>>>>> dvdwriter i am faced with exactly the same problem. i know i can
>>>>>>> increase my write speeds if i can get the devices to allow dma,
>>>>>>> but how??
>>>>>>> mboard-kd7 vanilla (no raid, no serial ata, etc)
>>>>>>> running winxp sp1
>>>>>>> primary master -80gb WD hdd
>>>>>>> primary slave -20gb maxtor
>>>>>>> sec. master -afreey 12x dvdrom drive
>>>>>>> sec. slave -liteon ldw-451s 4x dvdwriter
>>>>>>> PS- i tried switching the dvdrom and the dvdwriter with the
>>>>>>> result that the writer would not accept dma mode in either
>>>>>>> master or slave configuration. thanks!
>>>>>> This article may help explain why you're having the problem.
>>>>>> Near the bottom of the page, it shows you how to enable DMA (if
>>>>>> XP will allow it).
>>>>>> One other thought; you should be using a 80 conductor, 40 pin IDE
>>>>>> cable.
http://www.microsoft.com/whdc/hwdev/tech/storage/IDE-DMA.mspx
>>>>> ICee-
>>>>> Thanks for the help. Somehow tho, I've been able to change both
>>>>> optical drives from PIO mode by disabling UDMA access for the
>>>>> secondary ide channel in the bios. now both drives are running in:
>>>>> Multi-word DMA mode2 - whatever that is... hopefully since it has
>>>>> the word DMA in it then it is at least a little faster than PIO
>>>>> mode... PS- I am using a ata133-80conductor/40pin cable... forgot
>>>>> to mention it. If someone out there still wants to help me get
>>>>> these drives working in Ultra DMA mode- please! thanks everyone.
>>>>> Robbie
>>>> Well, you're up to 16.6 MB/s transfer speed with Multiword DMA
>>>> Mode 2 (twice POI mode 4 speed). Have you tried the DVD-RW drive
>>>> alone as master on the cable; does UDMA work then? What is the
>>>> maximum transfer speed of the DVD-RW?
>>>> I would try another cable and install the DVD-RW drive as master
>>>> and the other as slave. Some CD-RW/DVD-RW drives must be set as
>>>> master for them to work correctly.
>>> Icee-
>>> I'm going to try to enable UDMA with only the dvd burner installed
>>> as master on the 2ndary ide cable- if that works then the Afreey
>>> dvdrom drive is the suspected culprit in the whole deal; ironically
>>> it has had no trouble being set as UDMA !!
It kindof figures.
>> Sounds like a plan. Yes, sometimes different drives don't like to
>> play well with others.
Post back with the results and we'll go
>> from there.
> Icee- I got my copy of Nero finally so was able to play with the
> drives- and since I can do onthefly cd copies in about 6-7minutes and
> dvd copies in about 10-11minutes (that doesn't include decoding
> time-just burning time!) I am gonna leave everything like it is for a
> while. at least I'm not running in PIO and I feel like the drive is
> plenty fast as far as burn speed. especially for a 4x drive. Thanks
> again for the help-
> -robbie
Sounds good. Thanks for the update, and you're welcome.
