G
Guest
Guest
Archived from groups: alt.comp.hardware.overclocking.amd,alt.comp.periphs.mainboard.abit (More info?)
Hi,
Abit NF7-S rev 2.0 board with 2500 AMD....1 GB Crucial RAM....ATI AiW 9800
Pro....Maxtor 200GB, Pioneer 107D DVD.
Running Windows XP, this machine has been running fine for a few months with
no problems at all. A couple weeks ago, my machine suddenly rebooted itself
when I was in Windows. A couple days later, it did the same thing. It
gradually started to get more frequent.
I wasnt sure if it was hardware or some software I loaded that was causing
the reboots, so I decided to reload Windows XP from scracth to eliminate the
software side of things.
Well, it looks like it is hardware as Windows XP will not even install now.
It will boot off the CD-Rom and loads all the drivers, then gets to the
point during setup where it says "Setup is loading Windows"
At this point it will do 1 of 3 things:
1) Hang there with the "Setup is loading Windows" message at the bottom of
the screen
2) Reboot
3) BSOD - Page_Fault_In_Nonpaged_Area - 0x00000050
Any ideas??
Hi,
the screen
2) Reboot
Any ideas??
