G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.abit (More info?)
Greetings,
I am about to build a new computer and the two following configurations
will run me $350... which combo is the best?
Abit KV8-MAX3 with a Athlon 64 3000+
Abit IC7 MAX3 with a Intel P4 2.8CG (800MHz)
I like the AMD setup but I'm not sure if this board supports dual
channel DDR... will it? I will run PC3200 400MHz memory (2X512) on
either configuration...
Thanks as always for any clues you can give me!
Taylor
Greetings,
Taylor
