G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.abit (More info?)
Hi,
I have an AT7 (slight old I know) and a GeForce 4 Ti4200 and recently have
started getting small blue dots appearing on the screen. At first I thought
the graphics card was overheating and have tried fans blowing on it etc. If
after a while I reboot though the BIOS screen is corrupted with strange
figures, once the machine gets as far as the XP boot up screen its fine.
This is leading me to think it may be a BIOS thing since the graphics card
is not really being used during that initial screen with the memory check.
Has anyone ever seen this before? Other than the small blue dots the actual
screen is fine in the operating system, there are noticeable problems if you
load a 3d accelerated game though.
Ive never flashed a bios before,. I take it I just go and download the
latest file (Nov 2003 I think) and the utility and follow the instructions
in the manual. I will also get the latest drivers for the graphics card.
Thanks for any advice
Hi,
