NF7-S Problems!
Archived from groups: alt.comp.periphs.mainboard.abit (More info?)
I have recently installed the NF7-S and all went relatively well, however at
first it did not want to boot, by a process of elimination I have determined
it is to do with the additional USB & IEEE1394 panel.
It appears to work fine when plugged into the MOBO but not installed in the
case which would suggested that it is being earthed and thus the MOBO is
refusing to power on.
Anybody else come across this? if so does anybody have a solution?
Cheers
Soupladel
9 answers Last reply
More about problems
  1. Archived from groups: alt.comp.periphs.mainboard.abit (More info?)
    "Soupladel" <Soupladel@spamcan.blueyonder.co.uk> wrote in message
    news:FH8oc.532$W_5.4283536@news-text.cableinet.net...
    at
    determined
    the
    | Cheers
    | Soupladel
    Hi Soupladel -
    Best bet is to look for a motherboard pan standoff which doesn't mate with a
    hole in the motherboard. Alternatively, a standoff not properly aligned to
    the center of a motherboard hole could also be shorting adjacent traces on
    the motherboard.
    Jef
  2. Archived from groups: alt.comp.periphs.mainboard.abit (More info?)
    Soupladel said in news:FH8oc.532$W_5.4283536@news-text.cableinet.net:
    > however at first it did not want to boot, by a process of elimination
    > I have determined it is to do with the additional USB & IEEE1394
    > panel.
    > in the case which would suggested that it is being earthed and thus
    > the MOBO is refusing to power on.
    > Cheers
    > Soupladel
    Does "it did not want to boot" means the computer powers on but you do not
    get past the POST or no drive gets read to find an OS, or if the computer
    won't power up at all. If the problem is that the computer won't power up,
    and since 2 of the 4 wires are for power, maybe you have them reversed. If
    reversed and you attach the panel to the case, the 5v line shorts out to
    ground. The PSU protects by refusing to power up. See
    http://www.hardwarebook.net/connector/bus/usb.html for connections. Make
    sure yours are correct.
    ____________________________________________________________
    *** Post replies to newsgroup. Share with others.
    *** Email: domain = ".com" and append "=NEWS=" to Subject.
  3. Archived from groups: alt.comp.periphs.mainboard.abit (More info?)
    "*Vanguard*" <no-email@reply-to-newsgroup.invalid> wrote in message
    news:0NadnSpwXdwdhjzd4p2dnA@comcast.com...
    > > panel.
    > > Cheers
    > > Soupladel
    up,
    If
    Thanks for that but you *cannot* have the connectors for USB panel the wrong
    way round/miss-alligned as they are in a 2x5 pin block with the pin at the
    top right is missing and the connector has a blanked off hole to allign with
    the connector on the board, much in the same way that IDE connectors have
    the missing pin/filed hole in the centre!
    Soupladel
  4. Archived from groups: alt.comp.periphs.mainboard.abit (More info?)
    "Jef Norton" <jefn_REMOVE_YOUR_SHORTS_@sbcglobal.net> wrote in message
    news:2gck8fF18sm6U1@uni-berlin.de...
    however
    > at
    > determined
    > the
    > | Cheers
    > | Soupladel
    > Hi Soupladel -
    a
    to
    > the motherboard.
    > Jef
    I suspect it is because the case is hardly what you might call standard (It
    was once, many, many moons ago a Packard bell) for example the blanking
    plate that comes with the board to surround the sound & printer connectors
    etc... will not marry with the case (the slot is a shade too small)
    Soupladel
  5. Archived from groups: alt.comp.periphs.mainboard.abit (More info?)
    news:aY9oc.621$F_6.5673168@news-text.cableinet.net...
    (It
    | Soupladel
    Hi Soupladel -
    From that description: da-yup... I'd be looking for stuff touching the
    motherboard... or perhaps a new case even.
    Jef
  6. Archived from groups: alt.comp.periphs.mainboard.abit (More info?)
    Soupladel said in news:jV9oc.616$KG6.5269740@news-text.cableinet.net:
    >>> elimination I have determined it is to do with the additional USB &
    >>> IEEE1394 panel.
    >>> Cheers
    >>> Soupladel
    >> do not get past the POST or no drive gets read to find an OS, or if
    >> the computer won't power up at all. If the problem is that the
    >> computer won't power up, and since 2 of the 4 wires are for power,
    >> maybe you have them reversed. If reversed and you attach the panel
    >> to the case, the 5v line shorts out to ground. The PSU protects by
    >> Make sure yours are correct.
    > the wrong way round/miss-alligned as they are in a 2x5 pin block with
    > the pin at the top right is missing and the connector has a blanked
    > off hole to allign with the connector on the board, much in the same
    > way that IDE connectors have the missing pin/filed hole in the centre!
    > Soupladel
    Well, that's not true for all devices that connect to the mobo headers
    for USB. I have USB ports integral on the front of my case and each
    wire was a separate connector that slide onto a pin in the USB header.
    They were labelled (except I had to guess on the data wires but testing
    proved I got it right). I don't know what is this front panel for USB
    and IEEE1394 that you mention since you never mention brand and model.
    Might be you're talking about the Abit accessory "Media XP/Pro"
    (http://www.abit-usa.com/products/multimedia/mediaxp/). I chose not to
    guess.
    Is the other end of the cable that connects to the panel also keyed to
    ensure you cannot reverse that end? Or is it hardwired (i.e., crimped
    or soldered so that end of the cable cannot be removed)?
  7. Archived from groups: alt.comp.periphs.mainboard.abit (More info?)
    news:ivCdnTmbjopzTzzd4p2dnA@comcast.com...
    > >>> IEEE1394 panel.
    > >>> Cheers
    > >>> Soupladel
    > > Soupladel
    > guess.
    http://www.abit-usa.com/products/mb/techspec.php?categories=1&model=6
    The picture at the bottom of the page, Item in the top corner.
    It is actually an item that connects internally and installs into one of the
    spare PCI slots! I believe, the problem relates to the plate touching
    something on the case that is causing a short!
    Soupladel
  8. Archived from groups: alt.comp.periphs.mainboard.abit (More info?)
    Are you connecting a 2.0 USB port on the motherboard to a 1.0 port on the
    front panel?
    DDDD
    news:zTsoc.1752$B%.13560076@news-text.cableinet.net...
    > > >>> IEEE1394 panel.
    > > >>> Cheers
    > > >>> Soupladel
    > > > Soupladel
    > > guess.
    the
    > Soupladel
  9. Archived from groups: alt.comp.periphs.mainboard.abit (More info?)
    Soupladel said in news:zTsoc.1752$B%.13560076@news-text.cableinet.net:
    >>>> Soupladel said in
    >>>>> & IEEE1394 panel.
    >>>>> installed in the case which would suggested that it is being
    >>>>> earthed and thus the MOBO is refusing to power on.
    >>>>> Cheers
    >>>>> Soupladel
    >>> with the pin at the top right is missing and the connector has a
    >>> blanked off hole to allign with the connector on the board, much in
    >>> the same way that IDE connectors have the missing pin/filed hole in
    >>> the centre!
    >>> Soupladel
    >> headers for USB. I have USB ports integral on the front of my case
    >> and each wire was a separate connector that slide onto a pin in the
    >> USB header. They were labelled (except I had to guess on the data
    >> wires but testing proved I got it right). I don't know what is this
    >> front panel for USB and IEEE1394 that you mention since you never
    >> mention brand and model. Might be you're talking about the Abit
    >> to guess.
    >> to ensure you cannot reverse that end? Or is it hardwired (i.e.,
    >> crimped or soldered so that end of the cable cannot be removed)?
    > of the spare PCI slots! I believe, the problem relates to the plate
    > touching something on the case that is causing a short!
    > Soupladel
    I'd probably report the fault immediately to whomever you bought the
    motherboard to get a warranty replacement. Otherwise, you might get
    stuck having to buy a replacement (http://snipurl.com/6c8l) at a cost of
    $17 plus shipping.
    However, before sending it in, just go ahead and check for a short
    yourself. Use a multimeter, ohmmeter, or continuity tester to check for
    a short. It is possible the signal ground is supposed to be shorted.
    The backplates and the connections there would be a point of entry for
    ESD and EMI so the short from signal ground to chassis ground might
    limit the impact of ESD/EMI entry onto the signal ground wire and thwart
    it getting inside. Rather than wonder about a short, just check it.
Motherboards
