Advanced Micro Devices (AMD), which originally was scheduled to launch its dual-core Opteron processor in the third quarter of this year, may advance the launch to the middle of the second quarter, according to sources at Taiwan server makers. Read more
ATI has a problem in the latest Catalyst drivers. Read more
A man who obtained an advance copy of the animated film "Flushed Away" was arrested and could face as much as three years in prison after he uploaded the movie to the Internet. Read more
Sony Electronics plans to unveil on Thursday a new digital projection system for movie theaters, using a microchip it says will advance the industry and rival Texas Instruments market-leading product. Read more
Three dramatically different builds face off in a show of performance, defining the real value of each. Our mainstream system is designed to meet the needs of most users. Who should spend more and who can live with less? Read more
For the second to last day of our System Builder Marathon series, we add a $500 gaming PC to the mix. It's not going to be as quick as our other two builds, but we think Paul was able to get some serious value from this thing. Read more
We're following up yesterday's $4,500 behemoth with a more affordable $1,500 mid-range build. Let's see what sort of performance (and overclocking headroom) you can get when you spend one third of the money. Read more
This month's System Builder Marathon spreads the system prices out even further to $4,500, $1,500, and $500. Is today’s $4,500 system really worth three times as much as an upper-mainstream performance machine? Read more
| Bottom | |
| Author |
Thread : IC7-G Max II Advance Problem.
Profile: stranger
More Information
Archived from groups: alt.comp.periphs.mainboard.abit (More info?) Alright heres my problem. When I play any games on my pc that require any
Related Product
More Information
Archived from groups: alt.comp.periphs.mainboard.abit (More info?) As you suspect, the video card is by far the most likely cause of this
Profile: stranger
More Information
Archived from groups: alt.comp.periphs.mainboard.abit (More info?) leave the cover off the case and test to see if the same problem happens. I
Profile: stranger
More Information
Archived from groups: alt.comp.periphs.mainboard.abit (More info?) Yea the temps are in F. Took the side of the case off and it ran a little
Profile: stranger
More Information
Archived from groups: alt.comp.periphs.mainboard.abit (More info?) Left the cover off and it did almost the same thing. Instead of just a few
More Information
Archived from groups: alt.comp.periphs.mainboard.abit (More info?) Josh wrote:
Profile: stranger
More Information
Archived from groups: alt.comp.periphs.mainboard.abit (More info?) Running a goldstar 550w power supply. Running a Seagate Baracuda sata
Profile: stranger
More Information
Archived from groups: alt.comp.periphs.mainboard.abit (More info?) you have a good power supply with plenty of current available? I had some
Profile: stranger
More Information
Archived from groups: alt.comp.periphs.mainboard.abit (More info?) that processor temp of 125 is only around 52 C so that is not an issue at
Profile: stranger
More Information
Archived from groups: alt.comp.periphs.mainboard.abit (More info?) Got a goldstar 550w power supply. All the voltages seam to check out on my
More Information
Archived from groups: alt.comp.periphs.mainboard.abit (More info?) I had a vary similar problem last year, though not with a Radeon 9800. One
More Information
More Information
