Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > changing the motherboard and uP in PC system w/XP installed
Forum Windows XP : Windows XP General Discussion - changing the motherboard and uP in PC system w/XP installed
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
I am planning to upgrade my motherboard and processor in my PC.
I now have a P4-2.4B and Intel GEBV2 card. I want to get up to
3.2GHz HT 800MHz with 1MB cache and a suitable motherboard.
I intend to replace just my current board and processor with the new ones,
and keep on using the same case, kb, mouse, disk (with XP installed) and
cards. AND I want to avoid a OS reinstall (takes too long to install
all applications; although I expect a reactivation).
Is there a catch to this scheme? (If an eventual OS reinstall hassle will be necessary,
I will keep my current PC as is, as long as I can).
Some vendors tell me that in any XP system, a motherboard and or processor
change will require a format and reinstall. Is this true?
Thanks.
Sponsored Links
Lots of posts here regarding this problem. Look further into the rest of these for extra information.
You can reinstall / repair / upgrade without loosing all your personal settings and corrupting the registry.
http://support.microsoft.com/defau [...] US;Q315341
Reply to bar
The mobo, CPU change is drastic enough that a repair install
of XP is needed to get the new drivers required by the
changes. Intel will be shipping a mobo driver CD. I don't
know for sure what mobo you plan to buy, but if you but an
D865 mobo with on-board sound and graphics a repair install
and reactivation will probably be needed. If you are using
an AGP video card and move that new card it is just slightly
possible that the computer might not require reactivation.
In any case, sounds like a nice boost. You might need a
faster graphics card to keep up with the new FSB and CPU.
"eepazarc" <eepazarc@ehb.itu.edu.tr> wrote in message
news:A6C1D8E6-7E3A-4EF0-B925-50BEF39F7A4B@microsoft.com...
my PC.
up to
motherboard.
with the new ones,
installed) and
to install
and or processor
| Thanks.
Reply to Anonymous
Greetings --
Normally, and assuming a retail license (many OEM licenses are not
transferable to a new motherboard), unless your motherboard is
virtually identical (same chipset, same IDE controllers, same BIOS
version, etc.) to the one on which the other WinXP installation was
originally performed, you'll need to perform a repair (a.k.a. in-place
upgrade) installation, at the very least:
How to Perform an In-Place Upgrade of Windows XP
http://support.microsoft.com/direc [...] US;Q315341
As always when undertaking such a significant change, back up any
important data before starting.
This will also require re-activation, unless you have a Volume
Licensed version of WinXP Pro installed. If it's been more than 120
days since you last activated that specific Product Key, you'll most
likely be able to activate via the internet without problem. If it's
been less, you might have to make a 5 minute phone call.
Bruce Chambers
Help us help you:
http://dts-l.org/goodpost.htm
http://www.catb.org/~esr/faqs/smart-questions.html
You can have peace. Or you can have freedom. Don't ever count on
having both at once. -- RAH
> ones,
> and
> will be necessary,
> processor
> Thanks.
Reply to Anonymous
There are 1290 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
