G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.abit (More info?)
I had been having some problems with my older AT7 mobo giving intermittent
hardward errors and have luckily narrowed it down to a fan which covers my Via
KT333 not turning when I start up my system. If I start my system with my
chassis open and just give the fan a little nudge after I startup, it will start
turning fine and will continue to run, and any hardware errors will not occur.
While I can experiment with it, I thought I would first ask here among all the
knowledgable people about a solution. Do I need another fan and, if so, where
can I get one which matches the one on there ? Can the fan be cleaned or greased
in some way that it turns when I start my system ? Any help or advice before I
decide to play around with it myself and, possibly, fould things up so that it
does not turn at all ( yikes !!! ) would be greatly appreciated. It become
tiresome quickly to have to open my case each time I start my system to give the
fan a little nudge to get it turning.
Eddie
Eddie
