CPU Problem II
Forum Motherboards & Memory : Abit - CPU Problem II
Archived from groups: alt.comp.hardware.pc-homebuilt,alt.comp.periphs.mainboard.abit (More info?)
Thanks for all your previous replies, but I am still encountering problems.
When I first booted I received a message stating that a config file was
missing and the pc would not boot, this only happened once though.When the
XP2400+ CPU is installed and the PC is booted, the CPU isn't recognised i.e.
the CPU name isn't displayed. Also the USB connections are not activated, as
the mouse and modem do not activate, this is the only obvious problem and
there may be more. I'm assuming the board and CPU aren't completely
compatible from these errors.
Does anybody else have other suggestions?
Sponsored Links
Tom's Hardware > Forum > Motherboards & Memory > Abit > CPU Problem II
There are 1136 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
