G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.abit (More info?)
Hi, just installed this mobo in new case and am trying to figure out audio
connections to the case,front connectors.
Case front connectors given as Line Out & Mic
two cable sets
1) EARO-R red, two connectors
EARO-L white, two connectors
RESER VED Blk
2) Mic out, red
Mic in, white
AGMD, blk
Trying to work out connections to the FP-Audio1 connector on mobo, pins:-
1 Audio mic
2 Ground
3 Audio Mic Bias
4 VCC
5 Spkr Out right
6 Spkr Out right return
7 no pin
8 NC
9 Spkr Out left
10 Spkr Out left return
thanks
two cable sets
RESER VED Blk
2) Mic out, red
Mic in, white
AGMD, blk
1 Audio mic
2 Ground
3 Audio Mic Bias
4 VCC
5 Spkr Out right
7 no pin
8 NC
9 Spkr Out left
thanks
