News
Tclink demonstrates car-radiator based cooling system
Published on June 05, 2006
If regular computer cooling system aren't just enough, Tclink/Ebiz offers a liquid cooling system that uses an "automotive" radiator. Read more
IBM promises cooler chips with capillary-action and water jets
Published on October 27, 2006
IBM's Zurich labs have developed a new heatsink and water-cooling that promises to cool chips up to six times better than conventional air cooling. The heatsink contains tiny channels similar to the capillaries you would see in tree leaves and in human circulator systems. The channels allow either water or heatsink compound to spread more uniformly and thereby dissipate more heat. Read more
Thermaltake Working On Affordable Compact Phase-change Cooling
Published on March 14, 2008
Hacienda Heights (CA) - During a recent visit to Thermaltake's office, we learned that the company is working on creating a compact phase-change cooling solution - which would be affordable for the majority of PC enthusiasts who are looking into extreme overclocking of their processors. Read more
CeBIT 2008: New CPU and Water Coolers from Thermaltake
Published on March 08, 2008
If you need good cooling performance but one cooler just isn't enough, there is an obvious solution - just take two instead. It seems that is what Thermaltake's engineers must have been thinking when they came up with the DuOrb CL-P0464 cooler. It consists of two coolers stemming from the Orb series that are connected to the CPU cooling block via heatpipes. Read more
Latest Reviews & Articles
Power Supply Roundup: Part II
Published on November 07, 2008
In Part I of our power supply roundup, we went through five mainstream PSUs rated at up to 700 W. Round two sees us tackle another seven mid-range units in an effort to determine which power supply deserves your attention. Read more
Roundup: The Best Overclocking Software
Published on November 06, 2008
Interested in overclocking but not quite sure where to start? We round up some of our favorite software utilities for tweaking processors, memory, graphics, and chipsets. Read more
Tom's Holiday Buyer's Guide 2008, Part 1
Published on November 05, 2008
Welcome to the first installment in our six-part Tom's Holiday Buyer's Guide. In Part 1, two beautiful models help showcase some of our favorite no-hassle hardware gifts for 2008. Read more
Round Up: Five Powerful, Light Ultraportables
Executives, road warriors, and gadget geeks all lust after ultraportable notebooks. Five of these amazing machines battle it out in this roundup. Read more
  Tom's Hardware Forums » Motherboards & Memory » Abit » Quiet socket A system possible without water cooling or an..
Word :   Username :
Bottom
Author
 Thread : Quiet socket A system possible without water cooling or an..
Profile: stranger
More Information
Archived from groups: alt.comp.periphs.mainboard.abit (More info?)
How would one go about getting a quiet multimedia socket A based system? Can
you underclock, undervolt mobile athlons easily to where they wouldn't need
much cooling?
there is no .sig
Related Product
More Information
> much cooling?
Sure, get a quiet PSU. A case with good ventilation, lower vcore to 1.5v
or less, and clock the cpu to about 1500MHz. Use a silent type cpu cooler.
A TR2-M1 or -M3 is good, cheap and very quiet (21dba). If it still makes
too much noise lower the fan speed a little.
KT133 MB, CPU @2400MHz (24x100): SIS755 MB CPU @2330MHz (10x233)
Need good help? Provide all system info with question.
My server http://wesnewell.no-ip.com/cpu.php
Verizon server http://mysite.verizon.net/res0exft/cpu.htm
More Information
In article <ehLJe.491$dk5.29@newssvr21.news.prodigy.com>, Doug says...
> much cooling?
Look at the Zallman Flower CPU coolers.
Conor
-You wanted an argument? Oh I'm sorry, but this is abuse. You want room
K5, just along the corridor. Stupid git. (Monty Python)
More Information
pigdos@nospam.com says...
> much cooling?
Just been on a quest of achieving this. First thing I did was to replace
the CPU fan - I have a big Thermalright copper HS with a 90mm fan.
Replaced the old fan with a Vantec. Next, I replaced the fan on the mobo
with a passive heatsink, put a Zalman fanless heatpipe cooler on my
Radeon 9600 XT video card, and replaced my 3 old harddrives with a new
fluid bearing Seagate one (250 Gb, 7200 rpm). Replaced old PSU with a
420W Enermax. Got an Antec SLK 3000 case - this case mounts the
harddrives with rubber grommets to reduce vibrations being transferred.
It's pretty quiet now - I have to look for the led on the front of the
case to see if it's on when I walk into the room. But it's not silent. I
think the cpu fan still makes noise by inducing the case to vibrate
some.
All that cost me some $$$, but mostly I just replaced parts that were
quite old (PSU, hdd) or had to be replaced (old case too big to fit into
my new desk). Big difference though: before it sounded like a jumbo jet
taking off down the hallway :-)
-P.
Google Ads
