Despite the spot price of polysilicon still remaining high, a mild weakening sign has been seen over the recent month. Read more
Using GPS (global positioning system) data to measure how points on land move following an undersea earthquake could help geologists decide if the tremor will cause an ocean-wide tsunami. Read more
MIT researchers have started putting entire gas-turbine engines on tiny silicon chips. With the help of some military funding, researchers have fashioned millimeter-sized compressors, combustion chambers and turbines and placed them on layers of silicon wafers. Read more
Delft (Netherlands) - A PhD student at the Delft University of Technology in the Netherlands has constructed what he says is the world's most advanced walking biped robot. Read more
Atom is geared for low-cost, low-power netbooks and nettops, while the device is a poor choice for desktop PC applications. We show you why Core 2 is better, and give some guidance on how to pick the best power supply for your low-power application. Read more
Not only do we have four super-fast Radeon HD 4870 X2s to test, but also a list of 31 other graphics configurations including CrossFire and SLI setups. If you're in the market for AMD's fastest card available, you'll want to see this. Read more
Does a NAS device with high data transfer rate and a Web interface that is easy to configure actually exist? Synology shows how it should be done. But the enclosure is not without its faults, either. Read more
Our worldwide overclocking championship has begun and we wanted to introduce you to the everyday components our teams will be tweaking to supersonic speeds in a bid for a shot at $5,000. Read more
| Bottom | |
| Author |
Thread : Help plse - NF7-S2 - urgent
