News
Apple releases Boot Camp beta update
Published on August 16, 2006
Apple today released version 1.1 beta of its Boot Camp software that allows Apple users to run MacOS X side by side with Windows XP on an Intel-based Mac. Read more
ATI Catalyst drivers have a problem
Published on August 27, 2004
ATI has a problem in the latest Catalyst drivers. Read more
Atmel And Phoenix Technologies Partner On Pre-boot Biometrics
Published on March 05, 2008
Atmel and Phoenix Technologies announced the integration of Atmel's FingerChip biometric security solutions in Phoenix's FailSafe and SecureCore pre-boot Authentication (PBA) products. Read more
Intel offers Robson's choice to cut boot-up time, battery consumption
Published on October 18, 2005
Fast-paced executives and impatient souls might be happy to hear this one. On Monday, Intel unveiled a technology, called Robson cache technology, that uses the NAND flash memory to not only boot the laptop up in a flash, but also to open programs almost immediately. Read more
Latest Reviews & Articles
Power Supply Roundup: Part II
Published on November 07, 2008
In Part I of our power supply roundup, we went through five mainstream PSUs rated at up to 700 W. Round two sees us tackle another seven mid-range units in an effort to determine which power supply deserves your attention. Read more
Roundup: The Best Overclocking Software
Published on November 06, 2008
Interested in overclocking but not quite sure where to start? We round up some of our favorite software utilities for tweaking processors, memory, graphics, and chipsets. Read more
Tom's Holiday Buyer's Guide 2008, Part 1
Published on November 05, 2008
Welcome to the first installment in our six-part Tom's Holiday Buyer's Guide. In Part 1, two beautiful models help showcase some of our favorite no-hassle hardware gifts for 2008. Read more
Round Up: Five Powerful, Light Ultraportables
Executives, road warriors, and gadget geeks all lust after ultraportable notebooks. Five of these amazing machines battle it out in this roundup. Read more
  Tom's Hardware Forums » Motherboards & Memory » Abit » Boot problem with ICH5 RAID 0 on IC7-MAX3
Word :   Username :
Bottom
Author
 Thread : Boot problem with ICH5 RAID 0 on IC7-MAX3
More Information
Archived from groups: alt.comp.periphs.mainboard.abit (More info?)
I recently had a dual boot sys win/lin on a 200gb WD drive. However
through messing with it I have borked the MBR. SO before I did
anything else with that drive, I wanted something to recover some of
the data too.
Due to my extensive use of optical drives, my only option was SATA, so
I have gone the whole hog (as far as my budget will let me) and
purchased 2 36.7gb Raptors.
I sat down, read the manual, then read it again. I have been in the
BIOS, set bootable add in device to Onboard SATA Raid. Enabled all
onboard SATA controllers (even silicon image). Where the option in
the bios to use raid or ide 3 and 4 master I have set to raid. And
the raid rom has been enabled.
Boot priority is FDD,CD,HDD,Other (enabled)
I restarted, pressed CTRL-I at the appropriate point and configure the
2 identical drives to the RAID-0 configuration.
I inserted my Win XP Pro CD and booted, pressing F6 where appropriate
and installing all the XP SATA drivers from ABIT's floppy.
Windows installed without a hitch, and quickly too. At this point I
have just installed win, not added ANY of the windows drivers.
During the install, at the first restart, I had left the Win CD in the
CDROM. I waited while it said press anykey to boot from CD. I was
then confronted with 2 copies of XP (the latter being the one on my
200GB with the borked MBR) I ignored it and just selected the default
which was my new install.
I took the CD out and restarted.
INCORRECT SYSTEM DISK OR DISK ERROR
I out the CD back in, as when it first rebooted durring install I
didn't have this problem, and sure enough it scanned the CD. I
waited whilst it said press any key to boot from CD and it found the
install of win.
Took the CD out
Cd in
Windows
CD out
etc...
Please note that I did check and made sure that there was no
floppy in drive a:
There are 2 things I can think of to try. First is to update the
BIOS. I am on revision 13 atm. This may well help as several
revisions have been released since then. If that fails the only
other option I can see is to place a value in the IDE delay. But I
can't see that working.
Answers on a postcard please :D
If required, here are the full specs of my machine
3.0 GHz prescott cooled via Thermaltake SubZero4G
2GB of Corsair DDR400 (4x512MB)
Gigabyte GeForce 5950 Ultra
Sounblaster Audigy2 ZS
2x36.7GB Raptor
1X200GB WD(unknown model)
1x650w QTec PSU + 1x550w QTec PSU (linked together)
CD-Rom
CDRW
DVDRW
ThermalTake Hardcano 9 Fan controller and temp monitor
2x120mm case fans (intake) 3x80mm case fans (exhaust)
Related Product
More Information
Just one observation: When you install XP(or any of the previous NTFS
systems) it is essential that NO other drives or partitions exist in the
system. XP will still recognise partitions and systems even if you set the
bios to NONE for those drives. That may not be the reason why yours will not
boot after install, but just having another XP system or partitions present
while you install will give problems, not least of which is to make your new
installation some other drive letter than C which cannot be changed later.
Jim
Profile: stranger
More Information
Carrot.,
> Cd in
> Windows
> CD out
> etc...
Unplug ALL USB devices, and try again.
Jim
Using - Virtual Access(OLR), ZASS 6.0, & WinXP Pro w/SP2
http://www.virtual-access.org
More Information
By any chance, were you using Drive Image when you did your borking ?
Forrest
Motherboard Help By HAL web site:
http://home.comcast.net/~mobo.help/
On Sat, 20 Aug 2005 09:31:51 GMT,
>through messing with it I have borked the MBR. ...
< snip >
More Information
"Carrot." wrote in message...
That boot priority is unnecessarily complex. To install XP I set the primary
boot device to CDROM, then after first reboot I set it to HDD-0. The other
three options are disabled at all times, and indeed this (especially
enabling the "boot other device" option) may be part of your problem. "Boot
Other Device" in particular can cause all sorts of oddities, especially if
you have a flash drive or similar connected to your system.
> appropriate and installing all the XP SATA drivers from ABIT's
> floppy.
If your target drives were connected to the Intel SATA-RAID controller, you
didn't need to install all the drivers off the floppy. The Intel 82801ER
drivers alone would have done you fine.
The other thing it doesn't sound like you've checked is the Hard Disk Boot
Priority option in the Advanced section of the BIOS. Enter it, and make sure
that Bootable Add-In Device is set *above* your 200GB drive.
> floppy in drive a:
Again shows why you don't need floppy in the boot device order!
Updating wouldn't do any harm, especially seeing as the one you have now
doesn't even have proper Prescott support IIRC! However, I suspect that it
won't by itself solve your boot order problem, that's more a setup issue.
> If that fails the only other option I can see is to place a value in the
> IDE delay. But I can't see that working.
No that won't make any difference at all.
Richard Hopkins
Cardiff, Wales, United Kingdom
(replace nospam with pipex in reply address)
The UK's leading technology reseller www.dabs.com
More Information
Thanks for your replies guys. It is now working.
@ Nick Carter
Apart from the borked volume, no other copies of XP are present. And
that didn't appear to cause the problem.
@ Jim
No USB devs atm - sorry :D
@ - HAL9000
Nope - not using drive image, just teh base Debian installer, placing
grub in /dev/hda2 as opposed to the MBR (or at least that is what I
think/should have done)
@ Richard Hopkins
Yes the boot priority is complex, however I need it set thus for
normal use. It is still set thus atm.
Drives were set to ICH5 on the SouthBridge. My copy of XP is pre SP1
and I haven't slipstreamed it yet. Dunno if that matters, but
without going through the F6 options the RAID array does not show
itself as a drive to install to.
After Flashing the BIOS I set the priority for the addin dev higher
than the 200GB. I can't remeber if it was this way before I flashed
the BIOS and cleared the CMOS tho. (NB: even so, I wasn't even
getting the error message associated with the borked partition which
was a whole 5 or 6 lines).
So it seems it was either the BIOS, or the bootable add in device's
priority - or possibly both.
But now it works.
Just setting OnTrack onto my borked drive now :D
More Information
"Carrot." <jonathan.bond@runbox-dot-com.no-spam.invalid> wrote in message...
Good noos. :-)
> SP1 and I haven't slipstreamed it yet. Dunno if that matters, but
> show itself as a drive to install to.
Steady, I didn't say that you could get away without F6'ing at all, I said
that you needn't have installed *every* driver off the floppy (i.e. the SiI
and VIA ones) as you previously indicated you had done ("installing all the
XP SATA drivers from ABIT's floppy" ). You have to install the Intel drivers
if you want to install WinXP to the Intel controller, but you don't need to
install the others.
> flashed the BIOS and cleared the CMOS tho.
Unless you'd previously gone in and changed it, it wouldn't have been.
Default behaviour would have had the 200GB drive ahead of the RAID
controller in the boot order.
> (NB: even so, I wasn't even getting the error message associated
> with the borked partition which was a whole 5 or 6 lines).
The system would have booted from the RAID array, because you told it to,
but by setting the parallel ATA controller above the RAID controller in the
Boot Device Order, you effectively also put the CD drive(s) above the RAID
array in the boot order, which is why, when you remove the CD, the system
wouldn't boot, as your boot.ini file would then be wrong.
Good luck with fixing the other drive!
Richard Hopkins
Google Ads
