NF7S V2.0 Soundstorm problem
Anonymous
Motherboard Authority
Archived from groups: alt.comp.periphs.mainboard.abit (More info?)
When I use the Nvidia speaker wizard, I can hear sound fine through my 4
speakers, r-l front, r-l rear. But when I configure the wizard and get
it like I want it, then close the Nvidia utility, the rear speakers no
longer work. What am I doing wrong?
"Airman QPD" <airman.basic@gmail.com> wrote in message
news:Z5qdndd7RYznrZfeRVn-qA@netdoor.com...
> speakers, r-l front, r-l rear. But when I configure the wizard and get it
> like I want it, then close the Nvidia utility, the rear speakers no longer
Use the Windows speaker thingy (Advanced button) to check if it has the rear
channels set to line-in or microphone.
Dave
Anonymous
Neither option is checked. Should they be?
> Dave
Only if the speakers are plugged into those sockets.
Dave
"Airman Thunderbird" <airman.basic@gmail.com> wrote in message
news:p K2dndDdS7lypI3eRVn-2A@netdoor.com...
>> rear channels set to line-in or microphone.
>> Dave
Related ressources
Anonymous
In article <Z5qdndd7RYznrZfeRVn-qA@netdoor.com>, airman.basic@gmail.com
says...
May well be a software problem. Vanilla Winamp doesn't use rear
speakers, you need the Dee3 plugin. Nero Showtime and Cyberlink PowerDVD
don't use them until you enable it (and buy a plugin for Dolby5.1).
Freelancer uses them if you set it in options ...
does that help? -Peter (who spent an awfully long time messing around
with similar problems recently)
firstname dot lastname at gmail fullstop com
Anonymous
On Sun, 28 Aug 2005 22:33:59 +1200, Peter Huebner
>says...
Try the following :
From the back of the amp, two wires go into the computer :
-put the black in blue, and;
-put the green in green
From the nForce2 Control Panel :
-select No#1 'rear speakers connected to line in' double click speaker
icon brhs/advanced
-select 'no digital' output in 'speaker setup' in nForce Control Panel
¸ô¶ó
hi, i had similar problems with my soundstorm
either try nforce 3.13 drivers or d/l them and extract the soundstorm
utility and use that with current nforce drivers like 5.10
<borolad@myowseintheboro.org> wrote in message
news:2t44h15rebe9cck3h2dtuo0k43e3p1ukbj@4ax.com...
>>says...
> Try the following :
> icon brhs/advanced
> ¸ô¶ó
Anonymous
I just migrated KT7-RAID -> NF7S V2. Re-install of the OS (Win98SE).
All updates available from m$ have been installed.
Soundstorm problem: clicking on .wav files gets the desired response.
..mp3 and .wma files play micro-clips & skips, resulting in song
completion in about 1.10 the expected time.
Games sound files have the same horrible problem.
What's the first thing to try? Tell me which M should I R and I'll
RTFM.
Seems nobody (nVidia/Abit) has updated drivers for Soundstorm under
Win98SE...
Anonymous
In article <c4och19dmfbahd6i2vd6h2l00o0eq15po7@4ax.com>,
brian.brunner@verizon.net.prophet says...
> Win98SE...
Somebody here recommended I use Realtek drivers, although I wouldn't
know how to implement THAT.
Had a quick look at NVidia's site, and I can't find Win9x drivers
either. Ack. That stinks :-( The new Win2k/XP audio driver package they
have there fixed the same issues you're having for me, except it still
left the chanels all mixed up. It's a poor poor performance by their
software/driver people IMO. I am more than half decided that my next
mobo will NOT have an NVidia chipset (Nor an Intel one).
-P.
Ask the community
