News
SD cards in tight supply due to Toshiba production problems
Published on December 27, 2004
The supply of Secure Digital (SD) flash-memory cards is currently falling short of growing demand as Toshiba may be experiencing some production problems for its SD modules, according to sources with DRAM-module makers in Taiwan. Read more
Microsoft fixes critical IE problems
Published on December 14, 2005
Microsoft this week fixed a widely reported flaw in its Internet Explorer browser that had been used by attackers over the past few weeks to take over the PCs of unsuspecting users. Read more
E-voting worries focus on failures, not fraud
Published on November 10, 2006
Major electronic voting machine problems occurred in at least six U.S. states during the country's midterm elections, underscoring that system failure, not fraud, is the biggest issue facing future races, voting-rights activists and technologists said this week. Read more
Microsoft patches 20 security holes in February update
Published on February 14, 2007
Microsoft's monthly security update for February has gone live. Though it marks the first update since the consumer release of Windows Vista, none of the 20 fixes are for the new operating system. Read more
Latest Reviews & Articles
Tom's SBM: The $1,500 Mainstream PC
Published on October 29, 2008
We're following up yesterday's $4,500 behemoth with a more affordable $1,500 mid-range build. Let's see what sort of performance (and overclocking headroom) you can get when you spend one third of the money. Read more
System Builder Marathon: The $4,500 Super PC
Published on October 28, 2008
This month's System Builder Marathon spreads the system prices out even further to $4,500, $1,500, and $500. Is today’s $4,500 system really worth three times as much as an upper-mainstream performance machine? Read more
Can Your Old Athlon 64 Still Game?
Published on October 24, 2008
We'd all love to upgrade every time a new piece of gaming hardware drops, but that's an expensive proposition. You think your Athlon 64 system is fairly quick--any chance a simple graphics upgrade can bring it up speed? We're aiming to find out. Read more
Benchmarking With Intel's NAS Toolkit
Published on October 23, 2008
We've been publishing our networked storage stories using Intel's NAS Performance tool kit as our primary benchmark. But before we went any further, we thought we'd introduce the software package and its individual components. Read more
  Tom's Hardware Forums » Motherboards & Memory » Aopen » MK79G-N Problems
MK79G-N Problems
Word :   Username :
Bottom
Author
 Thread : MK79G-N Problems
Profile: stranger
More Information
Archived from groups: alt.comp.periphs.mainboard.aopen (More info?)
Hello,
I have put together a system for a client (my father-in-law, uh-oh)
based on the MK79-N (with an Athlon 2500+, 512MB 333Mhz RAM (not the
best, Apacer is the brand), 80GB Seagate HD, LG 4082B DVD-Burner and
WIN XP Pro SP1.
When I first built the system, I had a few problems. Thought it was a
bad install. Format and re-installed. No problems. After applying the
SP1 and rebooting, I got a POST screen with all garbage text, bad
characters really. I could still read the POST screen (sorta) but it
was garbled with characters that should not be there.
I WAS geting a full stop blue screen with the first install, just
after the Windows XP boot screen (the one with the logo and the 3
little blue scrolling blocks), but not after the second install.
At this point, nothing boots, no Windows XP boot screen, after the
POST (and, of course, a check to the floppy and CD for a bootable
disk) I get a black screen.
In the end I suspect the video.
So heres the questions:
Has anyone seen this problem?
How can I tell what version of the BIOS do I have?
And how does that work for integrated Video? Can I flash only the
video and not the BIOS? I only see BIOS upgrade on the Aopen website,
and the details dont mention any video issue fixes.
How can I tell FOR SURE that its the Video and not the RAM (remember,
the RAM is used for Video memory). I can install a PCI video can I
have lying around, but that might not prove that it was video. What if
the RAM just wont work well with the Video.
Heres my thoughts: Either swap the motherboard or swap the RAM.
What do you think?
Thanks in advance, folks.
Chris P
Related Product
C
Profile: stranger
More Information
"Chris" <cp98ak@yahoo.ca> wrote in message
news:cdd2b856.0405201546.2e492113@posting.google.com...
> Hello,
> WIN XP Pro SP1.
> What do you think?
> Chris P
More often than not, if you have problems getting XP to install without blue
screening, it is a RAM problem. I would recommend going to
http://memtest.org/ and getting their memory test utility. I don't know if
you have changed any BIOS settings or not, but if you reset the CMOS jumper
(read the manual) then all of the settings will go back to default. When you
get a video signal again, you can read the POST screen to get the BIOS
version.
Chris
Google Ads
